Rather watch than read? View the recording below:
To view Smokeball Reports:
1. Select Reports from the Smokeball home screen
2. From the drop down menu select the required Report
3. Set date range and other parameters from options on the right to filter the information to appear in the Report.
4. The Report will generate on screen
5. Use the action bar at the top of the Report to print or export the Report.
