This article will show you:
How to Create an If / Then / Else Dependent on Field Existing
How to Create an If / Then / Else Dependent on Field Equalling
How to Create an If / Then / Else Dependent on Field Greater than or Equal
How to Create an If / Then / Else Dependent on Ask
Add an If / Then / Else
- To add an If / Then / Else to a document, ensure that you are open in Precedent Creation/Modification mode
- Ensure your 'Show' radio button is set to 'Show Fields'
- Click on the If / Then / Else tab
- Select whether the If / Then / Else is dependent on an Automation Field or Ask from the If: drop-down
For example, I want to create a variable in my document where if a finance approval due date exists on my Matter I want a paragraph to show and if there is no finance approval due date on my Matter, I want no information to show
- In this example, expand Conveyancing Details and select the Finance Approval Due Date Automation Field
- From the Is: drop-down select 'Exists'
- Place the cursor at the end of the directly preceding paragraph
- Click Insert
- Highlight the paragraph that you want to appear if there is a finance approval due date and cut this information
- Delete the word true
- Paste the paragraph about the finance approval due date where the word true was (in between if then and else)
- Delete the word false (in between else and end if), as there is no information to show if there is no finance approval due date
- 'End If' indicates the end of the variable and should be included after the information you want to show if there is no finance approval due date
For example, I want to create a variable in my document where if 'Nature of Property' equals 'Residential Vacant Land' I want a paragraph to show about vacant land and if the 'Nature of Property' is equal to anything else, I want a paragraph about final inspections to show
- In this example, expand Property Details and select the Nature of Property Automation Field
- From the Is: drop-down select 'Equal'
- In the Equal box, type 'Residential Vacant Land' exactly as it is worded and formatted in the Property Details window of the matter
- Click Insert
- Highlight the paragraph that you want to appear if the property is Residential Vacant Land and cut this information
- Paste the paragraph about Residential Vacant Land where the word true was (in between if then and else)
- Highlight the paragraph that you want to appear if the property is anything other than Residential Vacant Land and cut this information
- Paste the paragraph about anything other than Residential Vacant Land where the word false was (in between else and end if)
- 'End if' indicates the end of the variable and should be included after the information you want to show if it is not Residential Vacant Land
If / Then / Else Dependent on Greater Than Or Equal
For example, I want to create a variable in my document if the Purchase Price is equal to or greater than $750,000.00 I want a paragraph to show about Capital Gains Withholding and if the Purchase Price is less than $750,000.00 I want no information to show
- In this example, expand Conveyancing Details and select the Purchase Price Automation Field
- From the Is: drop-down select 'Greater Than Or Equal'
- In the Greater Than or Equal box type '750,000.00' exactly as it is worded and formatted in the Conveyancing Details window of the matter
- Click Insert
- Highlight the paragraph that you want to appear if the property is equal to or greater than $750,000.00 and cut this information
- Paste the paragraph about Capital Gains Withholding where the word true was (in between if then and else)
- Delete the word false, as there is no information to show if the purchase price is less than $750,000.00
- 'End If' indicates the end of the variable and should be included after the information you want to show if the purchase price is equal to or greater than $750,000.00
For example, I want to create a variable in my document dependent on a custom field or Ask, such as if there is an Easement on the property I want a paragraph to show about Easements and if there is no Easement on the property I want no information to show
- In this example, you will first need to create an Ask
- From the If: drop-down select 'Ask'
- Select the relevant Ask
- In the Equal box, type 'Yes' exactly as it is worded and formatted in the Ask
- Click Insert
- Highlight the paragraph that you want to appear if there is an Easement on the property and cut this information
- Paste the paragraph about Easements where the word true was (in between if then and else)
- Delete the world false, as there is no information to show if there is no Easement on the property
- 'End if' indicates the end of the variable and should be included after the information you want to show if there is no Easement on the property
