Smokeball allows you to add Precedents in Word, PDF and Excel format. You can learn how to add a Word precedent by following the steps below.
Word Precedents can be automated and you will have greater flexibility over the style and formatting of Word Precedents.
- Open a Test Matter in Smokeball
For example: if you are creating a Purchase Precedent use a Purchase Matter - Access the Precedent Library
- Navigate to the Folder that you would like to add the Precedent to
- Click Add a precedent or right-click > Add a precedent
- Select to 'Create from a blank document'
If you are adding a PDF or Excel document to the Precedent Library, select 'Browse for an existing document' - Give your precedent a name
- Select the Create a Precedent Container
Letter, No Footer is used for documents where there is no sign off at the end of the Precedent - Select the Addressee
If the type of Addressee is not available, add them to the Matter using Matter Settings and then return to the 'Add a Precedent' screen - Click Create
- Your Precedent will now open in Microsoft Word
- If you are creating a Precedent from an existing document, please move on to the relevant section below
- If you are creating a brand new Precedent, please move on to the relevant section below
How to Create a Precedent from an Existing Document
- Open the existing document in Microsoft Word
- Highlight the body of the document and copy it (keyboard shortcut is CTRL + C)
Select everything below the Re: Line and above the Sign Off - Paste (keyboard shortcut is CTRL + V) the body of the document in the new Precedent
- Ensure that all existing automation fields from other document automation systems have been removed from the Precedent
Use the keyboard shortcut ALT + F9 to view the fields and remove them - Add any Smokeball Automation Fields, Asks or If/Then/Elses that you would like to the document
To learn how to automate a precedent, please refer to the relevant articles
- Click Save & Close in the top left-hand corner
- Try generating your Precedent by double-clicking on it from the Precedent Library
How to Create a New Precedent
- Type and format your precedent
- If your precedent is a letter, ensure that you only include the body of the letter (everything below the Re: Line and above the Sign Off)
Notes
- To amend a precedent, right-click on it and select Modify
- Select the 'None' Container if the type of Precedent you are adding does not require your letterhead
- Try to remember to use a 'Test' matter when creating precedents
- To change the Document Container, open the precedent in Modify mode and expand the 'Details' section
