Smokeball's calendar syncs directly with Outlook. Every event created in Outlook will appear in Smokeball and every event entered in Smokeball will appear in Outlook. Smokeball also will add calendar events to Activity Intelligence. The best practice is to create calendar events from a specific matter. Each matter has an Events tab that includes previous and upcoming events in relation to a specific matter.
Create Events
Creating a calendar event in Smokeball is very similar to Outlook where you can enter location, time, reminders, comments, etc. Simply click on the Event button on the Matter Action Bar.
Set Reminders
You can also add multiple reminders for one or more users. The reminder will come through in a separate window to the main Smokeball application where users will be able to snooze or dismiss them.
Did you know...
- You can create calendar events from the Home Screen Action Bar, but make sure you assign an appropriate matter (if applicable)
- You can check for any reminders by clicking on the bell icon on Smokeball Home Screen.
Create from Critical Dates
On various layouts in Smokeball where you enter Critical Dates, there will also be a Create Events or Update Events button.
Clicking on this button will allow you to create events any selected calendars right from here.
You may find a Group Calendar useful to add events to, such as Court Dates or Settlements etc.
Learn how to create a Group Calendar here
