Import Files into a Matter
While documents can be created directly in Smokeball, documents and folders created elsewhere can also be saved to your matters. When you import folders, the current folder structure is maintained.
How to Import Using the Import Button:
1. At the top of the Matter Screen, click the Import button and select File or Folder
2. Locate and select the (1) file or (2) folder you want to save.
3. Click "Open" or "OK".
Did you know
  • You can drag and drop from a folder or your desktop into the Documents & Emails section in a Matter
  • You can also drag & drop from open emails or anywhere else where documents are stored.
