To import documents from your computer into a Smokeball matter, simply click the Import button in the Action Bar in any matter.
From there you can select to import Files or Folders.
- Selecting Files will open a window to browse through your computer and locate the documents to be imported.
- You can select multiple documents at a time.
- Documents will then be copied into the Smokeball matter and will appear in the document list. The originals will not be affected.
- Selecting Folders will also open a window to browse through. With this option though you will select an entire folder to bring into the matter.
- When Folders are imported the Folder itself will now appear in the document list, containing all the documents originally in that folder.
- You can also access the Import Files or Folders options by right clicking within the document list in a matter.
- An additional method of importing documents is to Click-and-Drag files from a folder on your computer into the document list of a Smokeball matter. Please note this does not work with Outlook emails and attachments. For information on importing those items see our section on Email Basics and Outlook.
