1. Go to your Smokeball settings via the File tab or the cog wheel on your home screen.
2. Once you have opened your Smokeball settings navigate to the Integrated Searching section.
3. Choose a provider, click Authorise and then enter your Searching partners credentials.
4. You will see a notification to confirm that your account is now integrated
5. Once integrated you will then be able to chose whether you would like to have completed files and disbursement to return to your matter.
If you would like these to return to your matter you'll need to ensure both boxes are checked and select save.
