Word Field Shading
Word Field Shading
Word Field Shading is a helpful setting for you to see what fields are being automated from Smokeball. It is also very helpful if you are using InfoTrack: eSignatures with DocuSign.
How do I turn on/off field shading in Word?
To enable or disable the field shading option in Word, you will need to:
1. Open Word, go to File > Options
2. Under Advanced, scroll down to the section titled "Show document content".
  • Next to "Field shading" select "Always" to turn on field shading. You may need to close and re-open Word for the changes save.
3. Field Shading will show you what is automated in documents
