Time & Expenses: Activity Code
Activity Code for Quick Time/Fee or Expense Entry
If you find yourself creating similar types of Time/Fee or Expense entries, it is helpful to create activity codes to be able to save yourself time when creating entries.
How to create activity codes:
1. In Smokeball Settings, select Activities
  • (1) Make sure Time & Expenses is enabled
  • (2) Choose to round time entries on 6 minute or 15 minute increments
  • (3) See any existing activity code
  • (4) Select add to create an activity code. Note: The code will be max 5 characters.
2. Create a Fee Activity Code
  • (1) Name the code (max 5 characters)
  • (2) Enter a description that will appear on the time entry
  • (3) Select a rate for all staff or based on a staff member (if applicable)
3. Create a Time Activity Code
  • (3) Choose a default duration and rate(s) per staff member (if applicable)
4. Create an Expense Activity Code
  • (2) Enter a description that will appear on the expense entry
  • (3) Enter rate and quantity (if applicable)
5. Activity codes will be available to use when entering a Time/Fee or Expense Entry
Did you know...
  • You can enter as many activity or expense codes as you want
  • Codes will be available whether you do a quick time/expense entry, entry from the home screen, or in an individual matter
