Updating Smokeball
It is important to make sure that Smokeball is up to date. Just like with every other software program, it is key to ensure that the current version is running on your machine.
To check if Smokeball is up to date:
  1. Open Smokeball Settings.
  2. Check lower left corner to see if your Smokeball is up to date.
  3. To apply updates use the File Menu to apply updates
  4. If not, restart Smokeball to get the update prompt.
