Setting Up the Smokeball Calendar Sync
Here are a few short steps to establish the sync between the Smokeball calendar and an Outlook calendar.
  1. Open Smokeball Settings.
  2. Select “Outlook and Notifications”
  3. Click to enable the calendar sync.
  4. Refresh the calendar list. Select the calendar you want synced.
  5. Save.
It is also important to note that this will need to sync to a local calendar. Meaning, the Smokeball calendar needs to sync with your calendar. No shared or iCalendars.
