Scanning
Scanning
If you have a local scanner or a scanner that is plugged directly into your computer (like ScanSnap), you can scan documents directly from your Smokeball matters. If you utilize a network scanner where documents are emailed or sent to a shared drive, use the Importing Documents and Folders button instead of a Scan feature.
See How to Connect a ScanSnap to Smokeball or give our help desk a call when trying to set up a local scanner
How to Scan Documents in Smokeball:
  1. Click the Scan button and follow your scanning program’s prompts.
Did you know...
  • You can drag and drop from a folder or your your desktop into the Documents & Emails section in a Matter
  • You can also drag & drop from open emails or anywhere else where documents are stored.
