Default Document Folders
Matter Configuration: Default Document Folders
With Smokeball, you can create matter-specific default document folders that will automatically appear in the Documents & Emails area when a new matter is created.
How to Create a Default Document Folder:
  1. On the DEFAULT DOCUMENT FOLDERS tab, click Add a folder. You can add as many folders as you would like.
2. Click OK and  Save.
Did you know...
  • You can create sub-folders by creating the folder and dragging under the appropriate folder
  • You can create nested default matter-specific folders by right-clicking the source folder and clicking Add folder
