Default Notes
Matter Configuration: Notes
Smokeball allows you to create default matter-specific post it notes and checklists that will automatically appear in the NOTES widget when a new matter is created.
How to Create a Default Note
1. On the NOTES tab within Matter Configuration, click Add a note.
2. You can add a:
  • (1) Black Text post it note
  • (2) Checklist post it notes
  • (3) Change the color of how the note will appear in the matter
3. Once Saved, the notes will appear in new matters created
Did you know…
  • You can create a note within an individual matter. You can also Pin certain notes so they appear at the top of the list of notes
