How to Connect ScanSnap to Smokeball
With Smokeball's integration with ScanSnap, it is possible for you to scan documents and have them be saved directly to a matter. Follow this quick setup guide and start scanning today!
1) Click the "Show Hidden Icons" button on the bottom-right corner of your desktop and find the ScanSnap icon. It will be a blue icon with an "S" in the center.
 2) Right-click the ScanSnap icon and select "Scan Button Settings".
 3) If it is checked, uncheck the "Use Quick Menu" box.
4) Click "Add or Remove..." button.
5) Click "Add" button
 6) Type "Smokeball" into Application Name field. Then click "Browse" button.
7) Navigate to C:\Program Files\Smokeball\binaries and double-click "Smokeball Scan".
8) Click "OK"
9) Click "Close"
10) Check the box next to "Use Quick Menu"
11) Click "Apply"
12) Click "OK". You are now ready to use ScanSnap with Smokeball!
