Activity Intelligence Basics
Every activity completed through Smokeball is tracked through Activity Intelligence.
For activity done outside of Smokeball, you can create an activity and add it to Activity Intelligence.
Note: If you are logging time for billing, it may be easier to enter your time as a Time Entry.
Activity Basics
  • You can create an activity from the home screen or with a matter by selecting the Activity button.
    • Select the date, staff, duration, and assign the appropriate matter for the activity
    • Enter details of what you want to appear on Activity Intelligence and Save
  • The activity will appear in Activity Intelligence as a task.
Did you know...
  • You can create activities from the Home Screen Action Bar, but make sure you assign an appropriate matter
