Default Matter Stages
Stages is where you set your default Matter Stage. Matter Stages are a way to track the status of your matters from start to finish.
You can set up multiple types of stages that can be applied to matters. Learn more about Matter Stages.
How to Set Up Default Matter Stages
  • Select Stages in Matter Configuration and select the default Matter Stage
  • If you have not set up Matter Stages or none are available, review Matter Stages and set stages up in Smokeball Settings.
