Automate a PDF Document
Transform your existing PDF forms into automated PDFs mapped to fields in Smokeball.
Before you begin, the PDFs you wish to make automated must be:
  • Fillable – they have fields where you can type information in.
  • Non-interactive – the format of the page does not change depending on the content entered.
Also, download the PDF to your desktop in preparation to import it into Smokeball.
To create an automated PDF:
  1. Open an existing matter, then select Precedent from the Matter tab.
    blobid0
  2. Navigate to the folder where you would like the precedent to be located, then select Add a precedent.
    blobid1
  3. Select Browse for an existing document, then select the Browse button to locate the PDF in your desktop.
    blobid2
  4. The Is Automated PDF document box will now be ticked. Rename your PDF (if necessary), then select Create.
  5. Your document will open in the Smokeball PDF viewer and you will see existing PDF fields in the document (if any) located in the PDF Fields column. Learn more about using the Smokeball PDF viewer.
  6. Select any field in the document and check if you wish for it to be mapped to a Smokeball field. To map it, select the field from the Smokeball column on the right-hand panel. Repeat for all other fields.
    blobid3
  7. Select Save & Close from the top-left corner of the PDF viewer.
You can now open this PDF with any matter, with the fields you added automatically populating the document.
2 out of 3 found this helpful
