Connect Outlook to the Smokeball web app
Available on Smokeball Boost
Learn how to connect Outlook to the Smokeball web app to save emails to your matter.
This web-based Outlook Add-in is currently only available for firms on the Smokeball Boost plan and is in beta testing for Grow/Prosper+ firms. If you are on Smokeball Grow or Prosper+, continue using the Classic Outlook Integration to retain all features. For more information, refer to our Frequently Asked Questions on New Outlook. Conversely, if you are on Smokeball Boost, you cannot connect to the Classic Outlook Integration.
Regarding Microsoft emails hosted on GoDaddy
The New Outlook integration does not support Microsoft 365 email accounts hosted on GoDaddy.
  1. Open Outlook in the web browser.
  2. Select the Apps icon on the left panel and then select Add apps.
  3. Search for Smokeball in the search bar and click on Smokeball for Outlook.
  4. Select Add.
  5. Once the app has been successfully added, navigate back to your Outlook inbox.
  6. Select an email and click on the Apps icon on the right-hand corner of the email.
  7. Select Smokeball for Outlook. The Smokeball toolbar will appear from the right-hand side of the screen.
  8. Confirm your Country and click on Connect to Smokeball.
  9. A new window will open in your browser. Follow the prompts to log in. You may also be asked to log in to Microsoft to authorize the connection.
  10. Once you have logged in successfully, the Smokeball for Outlook toolbar will appear on the right-hand side. This is where your most recently worked on matters in Smokeball Boost will appear.
  11. For your convenience, select the Pin icon to keep the toolbar in view every time you use Outlook.
    If you accidentally close the toolbar, you can access it again by selecting the Apps icon in the email as seen in Step 6.
  12. To save an email to a matter, select Assign.
    The email will then appear in the Documents tab of the matter, as an .eml file. They will also be denoted by a Mail icon.
    • Click on the email to preview or download it directly from Smokeball Boost.
0 out of 4 found this helpful
