Learn how to use the Bank Statement Analyzer Archie App to save time analyzing multiple bank statements. This App can help you trace spending, flag unusual expenses, or prepare disclosure material without needing to manually tag data.
Uploading the bank statements to Archie
To get started:
- Open a matter in Smokeball and ensure you have bank statement PDFs in your matter files.
- Select the Archie tab and then select Apps.
Find Bank Statements Analyzer under the Explore Apps section on the left menu, then select Use App.
In the Upload Statements window, select Browse to choose your matter files. If you have already ran the Bank Statement Analyzer, you can click Add bank statements in the top-right corner of the screen, then you can select Browse.
Note: Maximum of 25 files, 10MB per file, and PDF files only. If you have more than 25 files, you can run separate instances of the Bank Statement Analyzer for the additional files.
Choose one or more PDF bank statements in the matter, then click Select. You can select up to 25 PDF files at a time, up to 10 MB per file.
Choose what Archie should be looking for in these bank transactions. You can also add keywords to the list by entering the word in the text field and selecting Add.
Select Analyze statements. Archie will take some time to upload and extract transactions from the bank statements. Do not exit this screen while it is uploading.
Once Archie gets to the Files are being processed... stage, you are free to leave and come back at any time; it will continue to run in the background.
Once Archie is done, your bank statements will appear in the Uploaded files tab.
Reviewing the Bank Statements
The Review transactions tab operates as your "workspace" for the uploaded bank statements.
Click on the column headings to sort the data, and click on a transaction to view its position in the bank statement PDF.
You can complete the following actions on this page:
Type a keyword in the search bar to search the transactions in the list that list the keyword.
Select Ask Archie to ask a question about the data in the bank statements.
Select a Date range to narrow down the list of transactions displayed on the table and graph (item 8).
Specify a minimum and/or maximum transaction amount to display in the list.
Select the transaction type to display in the list.
Choose an indicator to filter the list to display transactions with that indicator applied to it.
Select bank statements to include or exclude in the displayed list.
Select Show graph to view a column graph of all transaction dates in the specified date range.
- Export the list of transactions to an Excel spreadsheet, which can also be accessed from the matter's documents list.
- An Excel spreadsheet of all transactions uploaded to the Bank Statements Analyzer is automatically created during the upload process as well.
