Smokeball Bill and Boost Releases August 2026
Plan_BillBoost.svg
View all new features and refinements to Smokeball Bill and Boost for this month.
26th August 2026
[Smokeball Boost only] The Archived conversations section is now available when using the new Messages UI.
20th August 2026
  • The Web App has been updated with a new logo!
  • Failed charges on payment plans now give more descriptive error messages when you hover over them.
  • Fixed a bug where Invoice Title, Subtitle and Notes in a matter's Invoice Settings reset to None after navigating away from and returning to Edit Matter.
11th August 2026
[Smokeball Boost + Intake] Smokeball Intake has been updated:
  • You can now customize the background color of your Intake Forms as part of your firm's Branding Settings.
    • Options include Default, Brand Color, White or Transparent. Use Transparent when the form is embedded on your website and you want it to blend into your existing page design.
    • The background color applies to all existing and new Intake Forms for your firm.
  • Fixed an issue with a large blank space appearing in the generated PDF when a form includes multiple contacts in a group.
  • Fixed an issue where changing a form's message templates was not triggering the publish modal.
  • Fixed an issue where the checkbox and toggle box in Smokeball Settings > Intake Forms > General appeared cut off when selected.
  • Fixed an issue where the "leave without publishing" modal remained on screen after the previous 'publish form' modal was closed.
6th August 2026
  • Fixed an issue where hyphens could not be entered in Activity Codes in the Web App.
  • Fixed an issue where staff with Invoice Read Only permissions could not send or download Invoice Adjustment Detail PDFs.
  • The option to Send Via Client Portal has been added to the Invoice and Adjustment Detail view.
