Stamp Duty Calculator (QLD)
Home Transfer Duty Concession
There are four types of rates for home concessions available:
  • Home concession;
  • First home concession;
  • First home (new home); and
  • First home vacant land concession.
For more information on rates and their thresholds, please refer to Queensland Revenue Office (QRO) Home transfer duty concession rate page.
Important Update on "Multiple Concessions Apply" Feature
The Smokeball QLD Stamp Duty Calculator also has an option for when Multiple Concessions Apply. Previously, the calculator provided options to enter different concessions by way of fractions.
The options to enter the fractions has now been removed from existing matters with Settlement Dates from 8 June 2025. Please note, no existing data will be lost from your matter.
Matters with Multiple Concessions entered with Settlement Date pre 8 June 2025 will appear as follows:
Please use the Queensland Revenue Office (QRO) Transfer Duty Calculator to calculate mixed/multiple concessions. See When Multiple Concessions Apply for more details.
The QRO has introduced the First home (new home) concession and updated the First home vacant land concession for eligible transactions entered into on or after 1 May 2025.  A full transfer duty concession is available on residential land only.
The Smokeball Stamp Duty Calculator currently caters for properties which are solely residential land. Please refer to the QRO transfer duty calculator for a property which includes both residential and non-residential land.
First Home Owner Grant
The First Home Owner Grant (FHOG) is for eligible first-time home buyers who are buying or building a new home valued less than $750,000 (including land and any contract variations).
The FHOG amounts are as follows:
  • $30,000 for contract signed on or after 20 November 2023;
  • $15,000 for contracts signed before 20 November 2023.
For more information on eligibility, please refer to Queensland Revenue Office (QRO) website.
The QRO Application for the Queensland First Home Owners' Grant is also available for use in your Smokeball Precedent Library.
Additional Foreign Acquirer Duty (AFAD)/Foreign Purchaser Duty
Additional foreign acquirer duty/foreign purchaser duty is based on the foreign acquirer's interest of the dutiable value of the AFAD residential land.
The following rates apply:
  • 7% on or after 1 July 2018; and
  • 8% on or after 1 July 2024.
For more information on assessing and calculating additional foreign acquirer duty, please refer to the Queensland Revenue Office (QRO) website.
Using the Smokeball Stamp Duty Calculator
Smokeball’s Stamp Duty Calculator will check the following information from your matter to calculate Transfer Duty, concessions, AFAD and grants:
  • if an Unconditional Date has been entered, and if so it will use this date;
  • if no Unconditional Date is entered, it will use the Contract Date;
  • if no dates are selected, it will assume today’s date;
  • the entered dutiable value;
  • the Concession Type selected;
  • the Foreign Interest Fraction and Value for the FPD entered; and
  • if the Grant Type selected is First Home Owner Grant.
Purchase Matter Stamp Duty Calculator
Conveyancing Details: Contract & Settlement Details
  1. Go to Conveyancing Details layout and select the Contract & Settlement Details tab.
  2. Enter the Unconditional Date or Contract Date (or leave blank to use today’s date).
Conveyancing Details: Stamp Duty, Tax & Registration
  1. Select the Stamp Duty, Tax & Registration tab.
  2. Select your Concession from the Concession Type Dropdown (if it applies). At this point the concession will be applied to the Dutiable Value (or Dutiable Value Override Amount, if entered). The deduction amount will populate in "Less Concession", and the sub-total will populate in "Concession Duty";
  3. To calculate AFAD/Foreign Purchaser Duty, enter the Foreign Interest fraction and the calculated Foreign Purchaser Duty will appear in the Foreign Purchaser Duty field.
    If the Dutiable Value for Foreign Purchaser Duty is different, this can be entered in the Value for FPD field, and the Foreign Purchaser Duty will be calculated using this amount instead.
  4. Click on the Grant Type Dropdown and select “First Home Owner Grant” (if it applies).
  5. The Grant Amount field will populate with the applicable amount.
Transfer Matter Stamp Duty Calculator
The Transfer matter type's Stamp Duty Calculator found on Transfer Details similarly caters for:
  • Transfer Duty;
  • Home Transfer Duty Concession; and
  • Additional foreign acquirer duty (AFAD)/foreign purchaser duty.
It does not cater for the First Home Owner Grant.
To ensure you receive the most up to date calculations for your clients when multiple concessions apply, enter all the relevant details into the Queensland Revenue Office (QRO) Transfer Duty Calculator.
For example:
You will see that there are two options to select to obtain the Stamp Duty Payable figure:
  • to Report; and
  • to Calculate.
The Calculate option will calculate the Stamp Duty Payable and show you the result only:
The Report option will show the Calculation Details to obtain that result, which is helpful for cross checking and also saving to your matter should you need to reference it again:
The Smokeball Stamp Duty calculator now allows you to enter the amount obtained from the QRO Transfer Duty Calculator into the Stamp Duty Payable Override Amount field:
0 out of 1 found this helpful
