Entering Payment/Cheque Items in Settlement Financials
Learn how to enter payments in the Payments tab (Cheques tab in QLD) to finalise your Settlement Financials in a Conveyancing matter.
Accessing Settlement Financials
To enter the Settlement Financials layout:
  1. Open the matter in the Smokeball desktop app.
  2. Double-click on Settlement Financials in the Matter Info section.
This article will focus on the Payments/Cheques tab at the top of the Settlement Financials window.
To enter Adjustments, refer to Entering Adjustments/Statement Items in Settlement Financials.
Entering Payments/Cheques in Settlement Financials
The Payments/Cheques Tab will differ based on the matter type you are in.
Sale Matter
In a Sale matter, only the Payment Direction is available.
When the Agent’s Fees are greater than the deposit held, a Payment Item will appear here for the agent.
Purchase Matter
In a Purchase matter, the Amount Required to Settle and Payment Direction tables are available.
Completing the Amount Required to Settle
The Amount Required to Settle table is a reconciliation of the amounts the Purchaser needs to pay in order to settle i.e. the amount due on the Adjustment Sheet/Settlement Statement, plus Transfer/Stamp Duty, plus the Firm’s Invoice.
  • Add an Amount: Click on Add Amount to create any other additional amounts.
  • Remove an Amount: Hover over the amount and click on the corresponding red cross to remove an amount.
  • Firm’s Invoice: When billable fees and disbursements are added to Time & Disbursements, an Our Account item is automatically created for you.
    For NSW, QLD and VIC Sale matters, the Our Account amount will also reflect invoice adjustments, including credits and part payments. You can manually change or remove this amount if required, and your changes will be retained when the Settlement Financials layout is saved and reopened.
  • Amount due on Settlement line item cannot be deleted (the red cross is greyed out).
  • Stamp duty line item will only appear if there is Stamp duty payable, when it is unpaid or not marked as exempt.
Completing the Payment Direction
The payments you entered while creating the Adjustment/Statement items in the Adjustment/Statement tab will automatically appear in the Payment Direction table.
These items are greyed out and can only be modified or deleted by returning to the corresponding item on the Adjustment/Statement tab.
For each Payment select:
  • the source from the Paid From drop-down menu; and
  • the Payment Type from the drop-down menu.
Click on Add Payment to add any additional Payments required on settlement.
To remove a Payment, hover over the payment and click on the corresponding red cross.
Just like in the Adjustment/Statement Item List, Payee names denoted in brackets, i.e. [Council], are automated in your document from your matter. For example:
  • Council’s name will generate in your Settlement Financial precedents from the corresponding Council Contact Card on your matter; and
  • The ELNO’s name will generate from your ELNO selection in Conveyancing Details.
Vendor Payments
Ensure you mark which Payments will be coming out of what is owed to the Vendor. To mark a Payment as a Vendor Payment, select the Vendor checkbox against the corresponding Payee.
  • Only Payments marked as a Vendor Payment will appear on the Settlement Adjustment Sheet and the Settlement Instructions to provide to the other side.
  • The Council and Water Authority Payments are automatically marked as Vendor Payments.
The Total amount required to settle and the Total payments to be drawn should tally, for example:
Confirming Available Funds and Balances
You will see two sets of tables under the Payment Direction table:
Available Funds Balances
The left-hand table allows you to enter the available funds from the Bank, Trust and ELNO in the corresponding fields.
Based on what is selected in the Paid From column in the Payment Direction table, the system will calculate the total amount that is paid from Bank, Trust, ELNO and Client.
It will then display the total amount for the respective sources in the Less payment amounts row.
Vendor Balance and Balance Required to Settle
The right-hand table gives a snapshot of the total of the payments in the Payment Direction, allowing you to check that:
  • All Payments due to and for the vendor have been accounted for in the Payment Direction, else it will show that there is a balance left to be directed; and that
  • Other amounts required to settle have been accounted for in the Payment Direction (e.g. Firm’s Invoice, Revenue Office, ELNO, Land Titles Office), else it will show that there is a balance left to be directed.
0 out of 1 found this helpful
