Cost Assessment (QLD)
The Cost Assessment (QLD) matter type provides the necessary contact cards and layouts for Party–Party and Solicitor–Client Cost Assessments held in the Supreme Court.
  • Applicant and its sub-layout Details where you can select whether the applicant will be paying or recovering costs and where the total costs value can be entered
  • Respondent and its sub-layout Details where you can select whether the respondent will be paying or recovering costs and where the total costs value can be entered
  • Case Details
    Enter the case number, registry, division, list and court details
  • Previous Solicitor
  • Additional Contact
Precedent Library
The Cost Agreement (QLD) matter provides access to the Litigation (QLD) Precedent Profile with pre-set Precedent Library folder File Setup which include non-legally drafted precedents for everyday use, together with shortcuts to commonly used documents found under Court & Authority forms:
0 out of 1 found this helpful
