Learn how to use the Audio Transcription Archie App to generate a timestamped and labelled transcript of audio and video files in the matter.
Archie audio and video transcription limits
Archie can transcribe audio and video files up to 1 GB in size and up to 8 hours long.
- Video formats: mp4, mov, avi, mkv, webm
- Audio formats: mp3, m4a, wav, flac, ogg
Accessing the Audio Transcription Archie App
- Open a matter in Smokeball.
Select the Archie tab and then select Apps.
Find Audio Transcription under the Explore Apps section on the left menu, then select Use App.
Select Browse and choose one audio or video file from your matter. Then click on Select 1 Files.
Select Process.
Archie will begin transcribing your file. This may take longer for larger file sizes. Do not navigate away from this screen.
Once the upload is complete, select View Transcription.
The transcription will appear on the next screen.
You can also access the transcription from the main Apps screen.
Working with your transcript
Select the Play icon to listen to the audio. The transcript on the left will highlight each word in real time as it’s spoken.
Click on the Speaker tag to rename the speaker in the transcript.
The Summary tab on the right-hand panel displays an AI summary of the contents in the audio or video file. You can also select the Chat with Archie tab to quickly ask Archie a question about the file.
Select Download transcription to save the transcript to the matter as a Word document. The summary will also be included in the transcription file.
Access downloaded transcripts in the Archie-Transcripts folder of the main Documents list.
Frequently Asked Questions
Is the Audio Transcriptions Archie App available to all matter types?
Yes.
Is there an additional cost to using the Audio Transcriptions Archie App?
No, the use of the app is included in your Archie add-on.
Can Archie transcribe every word from my audio or video file accurately?
The transcription won't be perfect - from time to time, it may get individual words wrong, especially for words that sound similar to other words (e.g. "cull" being miss-converted as "call").
Can I edit the transcript?
You cannot edit the transcript directly from the Archie screen, as this would affect the syncing of the script with the audio playback. However, you can download the transcription and edit that if needed.
Why does my file show ‘We couldn’t process this file'?
Recordings over 8 hours can’t be transcribed. Split the recording into shorter files and try again.
