Planning and Environment Advice (QLD)
The Planning and Environment Advice (QLD) matter type provides the necessary contact cards and layouts for a Planning and Environment advice matter that has not commenced court proceedings.
The following Contact Cards and Layouts appear by default on a Planning and Environment Advice (QLD) matter:
  • Client
  • Other Side (and Solicitor)
  • Subject Land
    Enter the relevant address and title particulars
  • Development Details
    Enter the DA description and DA number
Uncommon contact cards are also available for selection on a matter-by-matter basis:
  • Interested Party
  • Expert
  • Barrister
  • Previous Solicitor
  • Additional Contact
Precedent Library
The Planning and Environment Advice (QLD) matter provides access to the Planning and Environment (QLD) Precedent Profile with pre-set Precedent Library folders which include non-legally drafted precedents for everyday use, together with shorts cuts to commonly used documents found under Court & Authority forms:
