Learn how to subscribe and unsubscribe to precedent profiles in Smokeball.
During onboarding, you should be subscribed to all relevant Precedent Profiles for your state. However, you may want to make changes to these if:
- You are doing a one-off matter in another state.
- There are some suites you do not use in that state and you wish to remove them.
Access Precedent Profile settings
To access Precedent Profiles:
- Select the Settings (gear) icon in the top-right corner of the Smokeball desktop app, then select Smokeball Settings.
- Navigate to Precedent Profiles from the left menu.
To access Precedent Profiles from the Precedent Library:
- Open an existing matter, then select Precedent from the Matter tab.
- The Precedent Library will open in a new window. Select the Settings (gear) icon on the top-right corner of the window.
Subscribe or unsubscribe from precedent profiles
- Check that the relevant state is selected on the top-right corner of the Precedent Profile Subscriptions list.
- Navigate to the Status column and tick to subscribe to the profile, or untick to unsubscribe from the profile.
When ticking Subscribe, you can choose to receive all or only some updates to the Precedent Profile.
Note: The following options only apply to Precedent Library changes released by Smokeball. Any changes made by your firm will remain unaffected.
Only change documents
Receive updates only when a precedent in this Precedent Profile is changed i.e. when a new version of a precedent is released. -
Accept all changes
Receive all updates to this Precedent Profile i.e. when precedents or folders are added, amended, moved, or deleted. -
Don't change anything
Do not receive any updates to this Precedent Profile i.e. no alerts or automatic changes will be applied.
- Select OK.
Next step
Once you've subscribed to a precedent profile, learn how to organise the contents of the profile to suit your workflow.
