QLD Discharge of Mortgage
To create a new Discharge of Mortgage matter, follow the steps below:
  2. Select State: QLD
  3. Select Matter Category: Mortgage
  4. Select Matter Type: Discharge of Mortgage
  5. Select which party you are acting for (Mortgagor or Mortgagee):
  7. Select 'Details' to enter the Loan Number, Mortgage Number, Payout Amount and Payout Amount Date for the Mortgage.
  8. Select 'Property Details' to enter the Address, Title References and Estate/Interest of the Security Property.
  9. To add Uncommon Contacts to your matter, open the Matter Settings and select the appropriate contact from the Parties & Data available for your matter.
