Using the Smokeball Timer
Learn how to use Smokeball's built-in timer to track time and fees easily.
Accessing the timer
The timer is located in the top-right corner of the Smokeball Desktop App.
It is also located on the top-right corner of the Time & Disbursements window when Pop Out is enabled.
To access the timer on the Smokeball Web App, click on Create/View Timers on the top-right corner of the screen.
Starting the timer
Click on the timer and select Add A Timer/Create Timer. The timer will begin immediately.
The timer can be paused/resumed by clicking the plus/play symbol.
You can add a subject line and matter to the timer so that when you stop, this information is automatically entered in the time/fee entry created.
Stopping the timer
Select the green tick next to the elapsed time to stop the timer.
A window to create a new time/fee entry will appear, with the time, subject and matter automatically filled in.
Using the timer on the Smokeball Mobile App
You can also access the timer from the Smokeball Mobile App, allowing you to record time away from your PC.
To use the timer:
  1. Select the Timer icon on the bottom of the app. Tap on the Plus button to create a new timer.
  2. Enter the subject of the time entry and tap to choose the matter.
  3. Once you are ready to start the timer, tap Save. The timer will begin counting immediately.
  4. When you're ready to create a time entry, swipe left on the timer. This will pause the timer (if it hasn't already been paused) and bring you to the time entry screen.
    Timer
  5. Fill in the details of the time entry and tap Save.
Frequently Asked Questions
Can I run a timer in a matter and in my Time & Disbursements screen?
Only one timer can be active at a time. If you start a new timer, any previously active timer will automatically pause.
Additionally, all timers across different screens are synchronised, so you can easily switch between screens and still see all of your active timers, regardless of which screen they were started on.
Will my timer continue to run in the background when I close Smokeball?
If you try to close Smokeball while a timer is running, a prompt will ask if you want to pause it.
Will I lose my paused timers if I don't convert them to a time entry before I close Smokeball?
No. When you re-open Smokeball and click on the timer, you will be able to see the previously paused timers.
Do my paused timers remain visible indefinitely, or do they delete after a period of time?
All timers remain in place until you either delete them or complete them.
Is there a limit to how many timers I can have showing on the timer menu?
No, there is no limit.
4 out of 6 found this helpful
