ou can enter a default hourly rate for each staff member that uses Smokeball using the below method.
- Ensure you have activated enabled the integration of Time & Cost Recovery in Smokeball Settings.
- From the Smokeball Settings Staff & Users tab, double-click on a staff member's name to open a staff card.
- Select the Billing tab.
- Enter your hourly billing rate excluding VAT.
- Select Save.
- The default hourly rate will be applicable for time entries added from Activity Codes, Activity , Time Finder and AutoTime; however, the default hourly rate can always be overwritten.
