Deposit trust funds for multiple matters
If you have received trust funds from a client with multiple matters, you can easily deposit the money into trust and then divide it accordingly with a few clicks. To do so:
  1. Navigate to the Accounts view.
  2. Under the Transactions tab, select the relevant trust account, if there are multiple.
  3. Select Deposit Funds.
  4. Under the Allocated Matters section, use the search to enter the first matter. Add an amount using the field to the right.
  5. Select the blue Add Matter link to add the next matter. Use the search to enter the client's next matter. Add an amount using the field to the right.
  6. Enter the amount to be divided to each matter using the fields on the right side of the Deposit Funds window.
  7. Select Process Only or Process/Open Receipt.
The Trust Account receipt will indicate payments across multiple matters.
Your Accounts View will also indicate the bulk transaction under the Description column.
3 out of 4 found this helpful
