Microsoft Word paragraph numbering issue - August 2026
Version 2607 of Microsoft Word has introduced a bug where paragraph numbering is not applied correctly.
As of 10 August 2026, Microsoft has not released a fix. The Word beta build still shows the issue, so there is no ETA.
Is my version of Word affected?
To check if you are on Version 2607:
  1. Open Microsoft Word.
  2. Click File in the top-left corner.
  3. Select Account (or Office Account) at the bottom of the left panel.
  4. Under Product Information, look for:
    • Version (for example, “Version 2607”)
    • Update Channel (for example, “Current Channel” or “Monthly Enterprise Channel”)
If you are on the Current Channel, it means you get new features and fixes as soon as Microsoft releases them. Unfortunately, this also means that you may get new bugs earlier, which is what has happened this time with Version 2607.
How do I resolve this issue?
This issue depends on Microsoft releasing a fix to the bug introduced in Version 2607. This would mean waiting for the next version to be released on the Current Channel.
However, we recommend switching to the Monthly Enterprise Channel which does not have Version 2607 yet as it only releases updates once a month. Staying on the Current Channel has caused issues recently (such as the 2601 bug).
Therefore, we recommend moving from the Current Channel to the Monthly Enterprise Channel, and remaining on it until Microsoft has fully resolved the issue.
Important Note: Moving Channels should only be done by your IT provider or System Administrator. Do not attempt to change the Channel yourself if your firm has managed IT.
Follow the Microsoft article for steps on moving Channels: Change the Microsoft 365 Apps update channel for devices in your organisation.
Interim workaround
While arranging to change to the Monthly Enterprise Channel, you can contact us to set affected documents to use Compatibility Mode so Word uses a different rendering engine. The bug sits in Word's standard rendering engine, so compatibility mode bypasses it.
Important limitations:
  • This option is not available in the Word user interface. It must be applied manually by a developer, per document, so it does not scale.
  • Compatibility mode uses Word's older rendering format. It may affect more modern functionality in a document. Nothing has surfaced so far, but we cannot rule it out.
  • Documents already set to compatibility mode will behave the same in all Word versions. They do not need to be reset when a new Word release comes out.
For these reasons, compatibility mode is a safe stopgap but not our preferred fix.
Frequently asked questions
Is this a Smokeball bug?
No. This is a Microsoft Word bug introduced by a recent Microsoft 365 update on the Current Channel.
Will the update from Microsoft fix this, and when?
Microsoft has not confirmed a fix. The current beta build still reproduces the issue, so we have no ETA. We are testing each Word release and will update this page.
Can a firm change their own update channel?
If Microsoft 365 is managed by an IT provider, they will need to make the change. Firms managing their own Microsoft 365 can usually change it themselves. It is not a Smokeball setting.
Will switching to Monthly Enterprise Channel affect anything else?
The Monthly Enterprise Channel is commonly used by businesses that want fewer changes and more stability. Your IT provider can confirm whether this is appropriate for your firm.
What is “compatibility mode” in Word?
Compatibility mode means the document was created in an older version of Word. Word keeps the document in an older format to avoid changing the layout, which can sometimes limit features or cause issues.
