My Smokeball is not connecting with Microsoft Word
If you're experiencing issues connecting Smokeball to Word, follow the troubleshooting steps below to resolve them.
Re-enable the Smokeball Add-in for Word
When Smokeball cannot communicate with Word, the Smokeball toolbar in Word will go missing. Try to reconnect the Smokeball Add-in:
  1. In a Word document, select File on the top left corner.
  2. Select Options from the bottom-left corner. Then, select Add-ins from the left menu.
  3. Under Manage: expand the drop-down list then select COM Add-ins. Then, select Go.
  4. In the list of Add-ins available, tick the Smokeball Toolbar  box and select OK.
Reinstall Smokeball
If Smokeball was installed before Microsoft Word, then the Smokeball toolbar and add-in will not appear in Word. You will have to manually reinstall Smokeball in this scenario:
  1. Go to Add or Remove Programs on your PC.
  2. Uninstall Smokeball.
  3. Download and reinstall Smokeball.
  4. Check that the Smokeball Toolbar add-in is ticked.
Update Word to the latest version
Ensure your Microsoft Office 365 for Business product is on the latest version. To update Microsoft Office:
  1. Open Word, then select File from the top-left corner.
  2. Select Account from the left menu.
  3. Navigate to Update Options, then select Update Now.
  4. Let Microsoft Office check for and download updates.
  5. Check that the Smokeball Toolbar add-in is ticked.
I'm still experiencing an issue with Word
If you've completed all the steps above and still experiencing issues, get in touch with our Support Team.
2 out of 35 found this helpful
