Send and manage Matter Intake forms
Learn how to use Smokeball Intake to collect data from your clients directly and automate this into your matter.
Creating a matter intake form from a lead that came through via lead intake? Select Convert to Matter on the lead to get started.
Create a new Matter Intake Form
Smokeball Intake contains forms tailored to the area of law your matter is in. To get started with sending an intake form to your client:
  1. Open the matter and select the Intake Forms tab.
  2. SelectĀ Share Form.
  3. Verify the details of the Contact and Email of the client. Then, select a form from theĀ FormĀ drop-down menu.
    The Form Preview window will automatically populate fields with information from the matter details if they have been filled in.
  4. Choose whether you wish to send this form via Communicate or email. Edit the message if needed.
    • SelectĀ theĀ Custom Field icon to insert specific fields from your matter into the message.
    • You can customize this message for all matters in Smokeball Settings > Intake > Client Messages.
  5. SelectĀ ShareĀ to share as a Communicate message or Open EmailĀ if sending the form as an email.
Monitor Matter Intake Form progress
Add the Intake Widget to your Dashboard to view the progress of intake forms across all your matters. It can be configured to display a number of all forms or a list of forms.
Manage shared Matter Intake Forms
On theĀ Intake Forms tab, you will see a list of all forms involving the client. Under theĀ Last ModifiedĀ tab you can track when the client has opened or started filling out the form.
Matter Intake Actions
Clicking on theĀ three dots icon on the form will open up a list of actions you can take on the form:
  • View - access the form from the client's perspective.
  • Send Reminder -Ā  send a Communicate or email message to the client as a reminder to complete the form.
  • Copy Link - copy the form's URL linkĀ
  • Edit Responses - edit responses on a shared form.Ā
  • Close - close access to the form, if you have collated all relevant data.
  • Delete - delete the form. This can only be done ifĀ theĀ Last Modified field shows "Not opened".
Send form responses to the matter
To view the responses that the client has entered so far, selectĀ View from theĀ three dots icon.
If they have only partially completed the form, you can save the partially completed responses to the matter by selecting the Save icon.Ā Note:Ā SelectingĀ Save Responses will overwrite any existing fields in the matter.Ā
Once the client completes the form, their responses will be automatically saved to the matter, and theĀ Save icon will be disabled.Ā
If the pre-configured matter intake forms do not meet your needs, you can also create custom matter intake forms.Ā
1 out of 2 found this helpful
