Intake Forms - Frequently Asked Questions
Below are some frequently asked questions about the Intake Form features in Smokeball.
Can my firm create its own intake forms?
If you are the Firm Owner, you can create a custom lead or matter intake form for your firm. To get started, follow the steps in the Create a custom Intake Form article.
Can I duplicate an intake form?
Yes, you can duplicate intake forms by navigating to your list of intake forms (File -> Intake Forms on the Desktop app or Gear Icon > Intake Forms on the Web App) and selecting the three dot icon.
How can I set up staff members to receive notifications when Intake Forms are completed?
Note: The following setting only applies for Smokeball Grow and Prosper+, as notifications are delivered via the Notification Center (bell icon) in the Smokeball Desktop App. With Smokeball Boost, the Form Sharer is the sole user who will receive completed Intake Form notifications. In addition to the Notification Center, completion notifications are also received on the Messages tab in the Smokeball Desktop App.
To define who should receive intake form completion notifications:
  1. Navigate to your Firm Settings and select Intake Forms from the left-hand menu.
  2. Select the General tab.
  3. Tick the roles that should receive notifications upon Intake Form completion. If you tick Staff, you can nominate the staff member/s that receive notifications.
To define who should receive intake form completion notifications for Web Inquiries:
  1. Navigate to Firm Settings, select Intake Forms from the left-hand menu.
  2. Select the Web Inquiries tab.
  3. If you previously created the Web Inquiry link, you can use the three dots icon in the link's row to Change Settings, select the Staff who should be notified, and click Update.
  4. If you have not already created a Web Inquiry link, you can select Create Link, choose the form to generate the link for, and select the Staff to notify upon form completion.
Can I filter out Lead or Matter forms from the global view?
Yes. Use the dropdown menu on the list of intake forms to display Matter forms, Lead forms, or all forms.
How do I get my firm's logo to be displayed on the intake form?
Ensure you have uploaded your firm's logo on Firm Details in Smokeball Settings. This is where the form will grab your logo information from.
Why is my list of intake forms empty?
If you do not see Intake forms when trying to create a new form, make sure you have set up your firm's practicing states and areas of law.
  1. Navigate to Smokeball Settings on the top-right corner of Smokeball and select Intake Forms.
  2. Select the Practice Areas tab and check that your states and areas of law are listed there.
  3. Select Edit to add or remove states or areas of law.
  4. Select Save.
Can I revert changes made to an Intake Form?
You can restore previous versions of an Intake Form by selecting Settings on the top-right corner of the form editor, then selecting Version History.
Versions are saved once a day at 11:59 pm [UTC -5:00]. A version is only saved if changes were made in the past 24 hours.
Reverting to an earlier version doesn’t delete newer ones, but any changes made in the 24 hours before the save time will be lost.
Why can't I delete a matter intake form?
The ability to delete a form is reserved for the situation where you have shared a form by mistake, e.g. to the wrong client.
To delete a form, the client must not have opened it. You can confirm this by checking the Modified column for the form, which should show Not opened.
If the client has opened the form, you will have to Close the form instead.
How do I configure multiple parties to fill out the same intake form?
There are two ways to configure your intake form to collect data from multiple parties:
  • When sharing a form where multiple parties can view each other's contact details (e.g. for real estate intake), create a set of grouped repeatable fields to collect their information. Additional parties can click +Add on the form to provide their details.
  • When sharing a form where multiple parties must not view each other's contact details (e.g. for family intake), avoid using grouped repeatable fields. Instead, include a single set of contact detail fields on the form. When Party 1 completes the form, their details will populate the Party 1 section in Matter Details. Similarly, when Party 2 completes the form, their details will appear in the Party 2 section of the matter.
I need help in sending and managing intake forms. What can I do?
Review our articles on sending a lead intake form or sending a matter intake form.
What anti-bot measures are there in the Intake Form process?
We have implemented the following measures to combat bot and spam responses:
  • reCAPTCHA runs in the background of the Intake Forms website.
  • Form submissions from the same device require a wait time between each submission.
  • Automated verification measures are run once a lead form is submitted, which assesses if the form is a genuine enquiry or spam. You can review flagged responses from the Intake Forms Dashboard, accessible from the left panel of the main Smokeball window.
8 out of 19 found this helpful
