Smokeball Bill - Create an Invoice
  1. Select the Create Invoice button under Invoices tab.
  2. On the new invoice page, enter the Issue Date, Due Date, and Debtor(s)/Client(s).
  3. Select Edit Invoice Options to choose your invoice template or modify the invoice title/sub-title.
  4. Review Time/Fees and Expenses.
    • Add additional fees or expenses by selecting the Add Entry links.
    • Review, Edit, or Remove Entries by using the checkboxes.
    • You can select the checkbox in the W/O column to write off any entry.
    • Select the circled arrow in the View column to open a pop-up Time/Fee Details window and edit the entry.
  5. Optional: Apply a discount or surcharge below the subtotal listed on the rightmost column.
    • Discounts can be given with a specific dollar amount or percentage of Time and Fees.
    • Use the buttons at the bottom of the column to preview the invoice or save it as a draft. Invoices remain as drafts until you are ready to send them to your clients.
  6. Select the Save Draft button to save a draft of the invoice.
    • Optional: You can also select the View Preview button to preview the invoice.
    • Select the three dots next to the Save Draft button to delete an invoice. If a draft invoice is deleted, all time, fees, and expenses are billable and available for a new invoice.
  7. Select the Final tab on the rightmost column to review payment methods.
    • Pay From Trust: make a payment from a trust account.
    • Pay From Operating Retainer: make a payment from the operating retainer account.
    • Pay From Credit: make a payment using credit.
    • Toggle Auto-allocate payments to allow Smokeball Billing select which account to apply funds from first based on your firm's settings.
  8. Optional: Use the toggles to send the invoice to the client via Email.
  9. Select the Finalize Draft button if you are ready to send the invoice to the client.
    • You can add payments, email the invoice to the client, or download a finalized invoice.
    • If necessary, you can Void, Edit, or Waive the invoice.
      • Note: If a payment is applied, you must delete it before you can edit or void the invoice.
    • You can also choose Setup Payment Plan for this Debtor.
    • The bottom right-hand corner will indicate if the invoice has been e-mailed, viewed online by the client, and when the invoice was finalized. blobid5.png
2 out of 8 found this helpful
