Kickcall is a 24/7 AI voice receptionist that answers every inbound call, captures caller details, qualifies inquiries, automates routine workflows, and ensures every conversation is handled professionally, so your team can focus on higher-value work.
Connect Kickcall to Smokeball
- From your Kickcall dashboard, click the settings icon in the top left.
- Select Integrations from the menu.
- Click Add Connection in the top right.
- Select Smokeball from the list of integrations.
- Fill in the connection details.
- Click Authenticate with Smokeball and log in with your Smokeball username and password. Once you sign in, Kickcall has authorized access to your Smokeball account.
Once you authenticate, Kickcall takes you to the Configure Smoke Ball screen, on the Credentials tab. You'll see a confirmation that the integration was reviewed and verified, along with your connection details. Click Edit here any time you need to update them.
Manage an existing connection
Go to Integrations to see every connection you've added. From there you can:
- Reactivate a connection that's been paused or disconnected.
- Delete a connection you no longer need.
