Migrations: How does data migration service work at Smokeball?
Did you just bring on a new attorney to your firm? Reach out to your Client Success Manager to learn more.
What is Data Migration?
Data migration is the process of transferring your existing firm’s data into Smokeball. You'll work closely with a dedicated Data Migration Specialist, ensuring you have expert support every step of the way.
Our goal is to ensure we transition your data as effective and efficiently as possible.
All practice management systems are different and not all data can be migrated from one system to another, however, we will work to bring over as much data as possible.
Ensure your firm's computers can run Smokeball by checking our system requirements.
Our Migration Options
We offer three tailored migration packages to suit different firm sizes, needs, and timelines:
  • Jumpstart: Best for smaller firms or those with CSV based data exports, Jumpstart provides a streamlined migration experience with self-serve tools, heavily supported by your Smokeball Team to get you set up fast.
  • ProStart: Ideal for larger firms requiring more in-depth data analysis support and the ability to migrate complex data. ProStart is equipped to handle challenging migrations, including older systems and legacy platforms using SQL databases.
  • PartnerStart: Expert-led migration service for complex systems, leveraging trusted industry partners.
Your Client Success Manager can help determine the right option for your firm.
Note: Jumpstart is a great option for any size firm! Get started here.
