In addition to being a secure messaging platform to share files on, the Client Portal can also be set up to help your firm with document reviews.
As a requester, find out how to send documents to other staff members for review or approval, directly from the matter you're working on.
Sending a review request from the document
To get started, create an Internal Matter Conversation in the matter file.
- Right-click the document that needs to be reviewed.
- Select Share, then select the Client Portal... option.
- From the staff list, add the reviewer/approver. Enter a brief message in the Message field asking for document review or approval.
- Select Send to notify the reviewer/approver of the new document and message.
Creating a task from a Client Portal message
If a Client Portal message is not enough notification for your review workflow, you can easily create a task from a Client Portal message.
- Go to the Messages tab in the matter file.
- Select the Internal Matter Conversation with the reviewer/approver.
- Hover your mouse over the message asking for approval and select the three dots next to the message.
- Select Create task.
- Fill in the details of the task in the New Task dialogue window.
- By default, the chat message becomes the task Name. Amend it as required.
- Change the Assigned to drop-down menu to the reviewer/approver.
- Add your firm’s preferred Category for review workflow tasks. This allows a user to see assigned review tasks in a task list.
- Select a Due date.
- Click Save.
