Change billing unit increments for time and fee entries
When you select Units when creating a time or fixed fee entry, 1 unit may show as 1 minute, 6 minutes, or 15 minutes.
You can switch between them according to your firm's needs by changing this in Smokeball Settings:
Change units in the Smokeball desktop app
  1. Select the Settings (gear) icon on the top-right corner to access Smokeball Settings.
  2. Select Time & Billing, then under Billing Units, select 1-minute, 6-minute, 15-minute or custom increments.
  3. Select Save.
Change units for a single matter in the Smokeball desktop app
  1. Open the matter and select Matter Info.
  2. Select the Billing tab and use the Billing Units dropdown menu to select 1-minute, 6-minute, 15-minute, or custom increments.
Change units in the Smokeball Web App
  1. Open the Smokeball Web App, then select the Settings (gear) icon to access Firm Settings.
  2. Select Time & Activities from the left panel, then under Billing Units, choose either 1-minute, 6-minute, or 15-minute increments from the drop-down menu.
  3. Select Save.
Change units in a single matter in the Smokeball Web App
  1. Open your matter in the Smokeball Web App and then select the Edit Matter link. EditMatter.png
  2. Select Billing Fees and Rates.
  3. Use the Billing Units Round To dropdown menu to select 1-minute, 6-minute, 15-minute, or custom increments.
  4. Select the Save Matter button.
7 out of 14 found this helpful
