Assign a billing frequency to a matter
Learn how to accurately track invoices by assigning different billing frequencies to specific matters.
  1. Open a matter file in the Smokeball Web App. Select Edit Matter in the top-right corner. EditMatter.png
  2. Navigate to the Billing Fees and Rates section and choose an option from the Billing Frequency drop-down menu:
    • Annually - choose a starting month
    • Monthly - choose all months, odd months or even months
    • Quarterly - choose the group of starting months
    • Hold - choose this to identify matters that are being worked on but should not be billed yet
  3. Select Save Matter.
View all invoices under a specific billing frequency
Use the Billing Frequency filter on the left panel of the Invoices and Create Invoices pages to view invoices with a specific billing cycle.
Filtering on the Create Invoices page will also allow you to easily create invoices in bulk, without having to manually remember the billing frequencies of specific matters.
3 out of 5 found this helpful
