Set up Stripe credit card payments
Smokeball has partnered with Stripe to provide a seamless credit card payment solution on invoices created in Smokeball.
Get paid faster, reduce time spent chasing debtors, and improve cash flow for your firm with Stripe credit card payments.
To get started, set up a Stripe account.
Note that standard Stripe transaction fees apply for both domestic and international credit card transactions.
Before you begin
Ensure you have entered your Operating Bank Account details in Firm Settings.
Connect your Stripe account to Smokeball
  1. Create a Stripe account. If you have an existing Stripe account, a new account will be created for you in Stripe once you connect it to Smokeball. This is normal as the Stripe Connect integration works like this to ensure your existing account is not changed.
    Important Note
    Separate Stripe accounts with separate email addresses must be created for each Operating account you wish to connect.
  2. Open the Smokeball Web App and select the Settings (gear) icon. Then select Firm Settings.
  3. Select Payment Provider from the left menu, then choose the account to link from the Linked Account Setup section. Follow the prompts to link your Operating Account for invoice payments.
  4. Once successfully connected, you’ll see an Active message:
  5. Under Invoice Payment Options, choose whether you want to:
    • Include a payment link on the invoice
    • Include a “Scan to pay” QR code on the invoice
  6. Set your clearance days. These are the number of business days you estimate that a payment will be processed by the bank before funds are cleared into your bank account/s. For more information on clearance days refer to our dedicated article on configuring clearance days.
How to record payment into an operating account from a credit card
When you send a PDF invoice to your client, a Pay Now button and QR code (if enabled) will appear under the amount due.
When you send an eInvoice to your client, the Pay Now button will show on the top-right of the screen.
Once your client selects Pay Now or scans the QR code on the invoice, they will be sent to a credit card portal powered by Stripe, and with your brand logo displayed on the top-left corner.
After they enter their card details and select Process, a deposit entry will be created in Smokeball, and payment will be applied to the corresponding invoice.
If part payment is made against multiple invoices, the payment will automatically apply to the oldest invoice first.
How secure are my client’s credit card details?
Credit card details do not go through Smokeball at all – they go directly from your client to Stripe. This ensures the payments are secure and meet all PCI compliance requirements.
Does Stripe accept international credit cards?
Yes, you can record international credit card details by selecting the correct Country from the drop-down menu. The Stripe fee will then be recalculated with the international fee amount.
Smokeball detects if an international card is used when you select a country other than Australia when entering credit card details. In turn, the international transaction fee will be calculated, and the total amount the client pays is now displayed directly above the Process button.
If your client has received a request to pay via the Credit Card Payment Portal, they can also use an international credit card to pay through that portal.
The Pay Now button does not appear on invoices
If your firm has connected to Stripe but payment options are not showing on the PDF invoice, refer to our troubleshooting guide to identify the reason.
Getting support with Stripe payments
The scope of Smokeball Support extends to resolving issues that occur when using Smokeball to collect or request payments via Stripe. For issues with the payment itself, e.g. funds being withheld by Stripe or issues with Stripe accepting your bank account details, please contact Stripe Support.
Frequently Asked Questions
For more frequently asked questions about the Stripe Integration, refer to our dedicated article on this topic.
3 out of 3 found this helpful
