Using the Data Import Tool in Smokeball
Plan_BillBoostGrowProsper.svg
Get started on your Smokeball journey by importing all essential contact and matter data from your previous legal software or other sources.
What can be imported?
  • Staff
  • Contacts
  • Matters
  • Matter Tags (only available on Grow & Prosper+ plans)
  • Matter Roles (only available on Grow & Prosper+ plans)
  • Matter Critical Dates (only available on Grow & Prosper+ plans)
  • Matter Archive Details (only available on Grow & Prosper+ plans)
  • Matter Account Balances
  • Activity Codes
  • Unbilled Time/Fee Entries
  • Unbilled Disbursement Entries
  • Invoices
  • Billed Invoice Entries
  • Memos (not available on Bill plan)
  • Tasks (not available on Bill plan)
  • Calendar Events (not available on Bill plan)
  • Safe Custody (only available on Grow & Prosper+ plans)
A full list of supported fields can be found here.
If you are on a Grow or Prosper+ plan and need data transferred from your previous legal software, please contact your Onboarder or Customer Success Manager, who will be able to discuss the available options.
Note: Only Firm Owners have access to the Data Import tool in Smokeball.
Step 1: Preparing your source data
Prepare your source data to ensure a smooth upload and import process. To get started:
  1. Export the above listed data from your previous software into any of the following file types:
    • CSV (comma-separated values)
    • XSLX (Microsoft Excel 2007 and later)
    • XLS (Microsoft Excel 97 to 2003)
  2. Follow the Preparing your source data for import article.
We recommend importing only relevant/active data, for example, minimising importing items such as "Closed" Matters and "Completed" Tasks where possible.
Step 2: Starting a new import
Once your data has been formatted as per the recommendations outlined in Step 1, you are ready to upload it to Smokeball.
  1. Select the gear icon in the lower-left corner of the Smokeball Web App, then select Data Import.
  2. Select New import.
  3. In the text box provided, select the system your data is coming from. If you can't find your system in the list, type a custom value, then select this option from the menu.
  4. Choose the items to include in the import, then click Proceed.
  5. Select Upload under the data you wish to import into Smokeball.
    • Note: Some data types are unavailable (greyed out) until prerequisite data is uploaded and clear of errors.
    • Selecting Cancel import will discard all data under this import, allowing you to start over.
Once an import has been started, it will appear on this screen as In-Progress.
You can come back to this at any time before submitting the import.
Step 3: Mapping columns
Once a file has been uploaded, it is time to map the columns you have in the file with Smokeball's data columns.
  1. Select the row that is the header row in your source data. This step will be skipped if the tool can automatically detect the header row.
  2. Click Next.
  3. You will now be presented with the Map columns window. Under the Destination Columns section, use the drop-down menu to select a suitable destination field for each uploaded column.
    • The Sample Data column displays a preview of data from the corresponding column in the source data. (e.g. the Sample Data for the 'Last Name' column will extract Last Names from your source data).
    • The tool may automatically map some columns that it thinks will match with your data. You can change this by choosing another option from the Destination Columns drop-down menu.
    • Select Suggest mappings (not always available) at the top of the table to use AI-generated recommended mappings. We recommend reviewing the suggestions before proceeding.
  4. Click Next once done. You may only proceed if all Required Columns have been mapped.
An error message may appear if a required column has not been mapped, indicating the problem column that needs to be mapped.
If your source file does not contain a column that can be mapped to a "Required" Smokeball column, the following actions will need to be taken:
  1. Close the mapping view.
  2. Open your source data file (in Excel or similar) and add a column that can be used to map to the "Required" Smokeball column (the column name does not need to match the Smokeball column name).
  3. Re-upload the source file and proceed to map the columns.
Have issues with mapping columns? Review Preparing your source data for import to fix common pitfalls, then re-upload your file.
Step 4: Reviewing the uploaded data
Once mapping has been completed, all the data will be presented in a table. This view points out any validation issues in the data and allows you to edit the fields directly before saving the upload.
Any errors in the data are highlighted in red.
Any warnings in the data are highlighted in yellow.
The right-hand panel also shows a summary of all errors and warnings. Where a suggested fix is available, you can select Fix formatting errors to fix multiple errors in a column in bulk.
Click on the counter filter to filter the view by rows containing specific issues.
Click again to clear the filter and show all the data.
Some other useful tips to help navigate and edit data:
  • Filter tabs to the top right of the data to show clean rows/rows with issues.
  • "Find and Replace" button
  • Keyboard shortcuts:
    • Ctrl + Z = undo
    • Shift + arrows = select cells
    • Backspace or Delete = delete value from cell(s)
    • Ctrl + F = find a value
Additional rows can also be added directly from this view using the "Add Row" Button.
From this screen, you can Save a file upload.
You can save with errors and warnings still present and, if required, come back to continue fixing later. All errors must be fixed before the overall import can be submitted.
The Data Import screen will show a summary of any errors and warnings still present in the data.
At this point, you are free to close the tool and resume the in-progress import later.
To make any further adjustments, select Edit to reopen the uploaded data.
The overall import cannot be submitted until all data types are clear of errors (the import can be submitted with warnings). Refer to the summary of import errors from the import screen.
Repeat the above steps for every data type you wish to upload.
Matters & Matter Types
If importing Matters, an additional selection is required when uploading your Matter source file to indicate if you are importing matters within your firm's state only, or also other states.
The selection made here will dictate the Smokeball Matter Types shown to you when you reach the Matter Type mapping stage, where you will map your input Matter Types to those supported in Smokeball.
When mapping your input Matter Types to Smokeball Matter types, some Smokeball Matter Types have multiple "acting for" options, for example, Loan Agreement - Borrower and Loan Agreement - Guarantor. Where this is the case, you will see various options available for selection in the Smokeball Matter Type dropdowns and can select the most suitable choice.
In the above example, "ACT" is the state, "Commercial" is the matter type category, "Loan Agreement" is the matter type, and "Borrower" is the "acting for" role.
TIP: When mapping matter types, expand the column widths to get a better view of the dropdown options.
Step 5: Previewing & Submitting the import
Once you have uploaded, mapped, and fixed all outstanding errors across all data to be imported, you can preview and submit the import using the Preview & Submit button in the top-right corner.
Preview gives you a holistic review of your prepared import data before you submit it to your account, covering Staff, Contacts, Matters & Matter Type Mapping, Financials, and more. Each of these is shown in its own interactive, searchable, and sortable view, so you can quickly find and check the records you care about. Items such as Matters, Contacts, Invoices, Tasks, and Memos also have a detailed view, showing the full record along with any associated or linked records. A financial summary is also included at both an import-wide and matter level, so you can confirm the numbers are what you expect.
Use Preview to check that the data is accurate and complete, and to catch anything wrong while it's still easy to fix. If something's not right, you can fix it directly within the import tool using the Edit button on that item, or correct your source file and upload it again. You can repeat this correction-and-review cycle as many times as you need before submitting the import.
A few import items are not yet previewable, including matter roles, matter tags, calendar events, and safe custody. If your import contains only items that are not yet previewable, you will see this submission confirmation pop-up, bypassing the ability to preview your import. Otherwise, you will be taken to the preview screen.
When you're ready to submit your import, click the Submit button in the top-right corner of the Preview screen. Then confirm in the confirmation prompt
Once an import is submitted, it cannot be reversed.
On the Data Import screen, the import status will change from In-progress to Submitted.
Once the import has been validated, the status will change to Loading.
Then Complete, and your data now resides in Smokeball.
Clicking "View summary" will show a count of data included in the import.
Troubleshooting
Validation
Once an Import has been submitted, if further validation issues are identified in the data, the status of the import will change to Failed Validation. A downloadable error file will be available to indicate the problem data, allowing you to re-open the current import, fix and any issues, then resubmit it.
Failed records
If an import completes but some records failed to load into Smokeball, the status of the import will be Complete and a downloadable error file will be available to indicate the failed records and reason for failure. Using the error file, a subsequent import can be performed for the failed records.
Unexpected
Once an Import has been submitted, if an unexpected system issue occurs, the status of the import will change to Failed Validation. If this is the case, please contact Support via the top right help (?) icon.
I need help with formatting and mapping my data.
Refer to Preparing your source data for import if you encounter any issues with mapping columns in the Data Import tool.
Supported Fields
Staff
Column Name Required/Optional? Notes
Staff ID
Required This is a unique identifier used for a Staff Member. This ID will not be visible in Smokeball and is an internal identifier only.
Title
Optional
First Name
Required
Middle Name Optional
Last Name
Required
Initials
Optional
Email Address
Required
Must be unique
Current Staff
Required
Is the staff member current/active (yes/no)
Contacts
Contact ID Required A unique identifier used for a Contact. This ID will not be visible in Smokeball and is an internal identifier only.
Type Required Must be a "Person" or "Company" (Firm/Business/Organisation). If not provided, where possible, this will be auto-populated.
Full Name Optional
This field should not be mapped in conjunction with First Name/Middle Name/Last Name.
If used for mapping, the import tool will automatically split the full name out to First name, Middle name, Last name, or Company name.
Title Optional Title of the Contact
First Name Required if Type is "Person"
This field should not be mapped in conjunction with Full Name.
Less than 200 characters.
Last Name Optional
Company Name Required if Type is "Company"
For "Company" type records, the name of the contact goes here.
For "Person" type records who are associated with a company/organisation, enter the associated company name here, as well as the person's name (in full name OR first/middle/last name).
Doing Business As Name Optional Optional. Can be used if a Company contact has a business name that differs from the company name (trading as/practising as).
ABN Optional Australian Business Number (ABN) for a Company contact.
Job Title Optional Job Title of the Contact
Phone Optional Phone of the Contact (applicable to both `Person` and `Company` contacts).
Mobile Phone Optional Mobile Phone of the Contact (applicable to `Person` contacts only).
Work Phone Optional Work phone of the Contact (applicable to `Person` contacts only).
Business Fax Optional Business Fax of the Contact  (applicable to `Company` contacts only).
Birthday Optional DD/MM/YYYY
Birth Suburb/Town Optional The birth town/city of the contact. Field not available on the Bill and Boost plans.
Birth State Optional The birth state of the contact. Field not available on the Bill and Boost plan.
Birth Country Optional Birth country of the contact. Field not available on the Bill and Boost plans.
Date of Death Optional Date of death (DD/MM/YYYY). Field not available on the Bill and Boost plans.
Death Date Unknown Optional Indicated the contact death date is unknown (defaults to 'No' if left empty). Field not available on the Bill and Boost plans.
Death Suburb/Town Optional The town/city of the contact's death. Field not available on the Bill and Boost plans.
Death State Optional The state of death of the contact. Field not available on the Bill and Boost plans.
Death Country Optional Death country of the contact. Field not available on the Bill and Boost plans.
Gender Optional Gender of the Contact. Field not available on the Bill and Boost plans.
E-mail Address Optional
Can take multiple (; separated).
Less than 255 characters.
Full Address Optional
This field can be used if your input address data has multiple address parts (e.g. street/suburb/state/post code/country) combined on one line/in the same cell.
If used for mapping, the import tool will automatically split the street address information out to the detailed format address fields, including the suburb/state/post code/country.
Street Address Line 1 Optional
Simple format address fields.
If used for mapping, the import tool will automatically split the street address information out to the detailed format address fields.
These fields should not be mapped in conjunction with the Full or Detailed format address fields.
Street Address Line 2 Optional
Care Of Optional
Detailed format address.
These fields should not be mapped in conjunction with the Full or Simple format address fields.
Building/Level Optional
Unit Type Optional
Unit Number Optional
Street Number Optional
Street Name Optional
Street Type Optional
Suburb Optional
State Optional
Postal Code Optional
Country Optional
Full PO Box Address Optional
This field can be used if your input PO Box address data has multiple address parts (e.g. street/suburb/state/post code) combined on one line/in the same cell.
If used for mapping, the import tool will automatically split the street address information out to the detailed format PO box address fields, including the suburb/state/post code.
PO Box Optional
Simple format address.
If used for mapping, the import tool will automatically split the street address information out to the detailed format PO box address fields.
These fields should not be mapped in conjunction with the Full or Detailed PO box address fields.
PO Box Care Of Optional
These fields should not be mapped in conjunction with the Full or Simple format PO box address fields.
PO Box Type Optional
PO Box Number Optional
PO Box Suburb Optional Suburb for the PO Box.
This field should not be mapped in conjunction with the full PO box address field.
PO Box State Optional State of the PO Box.
PO Box Postal Code Optional Postal Code of the PO Box.
DX Address Number Optional DX Address Number. Only valid for Company contacts.
DX Address Exchange Optional DX Address Exchange. Only valid for Company contacts.
DX Address State Optional DX Address State. Only valid for Company contacts.
Full Registered Agent Address Optional Only valid for Company contacts. This field can be used if your input registered agent address data has multiple address parts (e.g. street/suburb/state/post code/country) combined on one line/in the same cell.
Registered Agent Address Line 1 Optional Only valid for Company contacts. Simple Format: Street Address Line 1.
This field should not be mapped in conjunction with the full registered agent address or detailed registered agent street address fields (care of, building, unit type, unit num, street num, street name, street type).
Registered Agent Address Line 2 Optional Only valid for Company contacts. Simple Format: Street Address Line 2.
Registered Agent Address Care Of Optional Only valid for Company contacts. Detailed Format: Address Care Of - e.g. "C/- ABC Law Firm".
This field should not be mapped in conjunction with the full registered agent address or simple registered agent street address fields (street address lines 1 and 2).
Registered Agent Address Building/Level Optional Only valid for Company contacts. Detailed Format: Address Building / Level - e.g. "Building 2" or "Level 23".
Registered Agent Address Unit Type Optional Only valid for Company contacts. Detailed Format: Address Unit Type - e.g. "Flat" or "Unit" or "Suite".
Registered Agent Address Unit Number Optional Only valid for Company contacts. Detailed Format: Address Unit Number - e.g. "12" or "13B".
Registered Agent Address Street Number Optional Only valid for Company contacts. Detailed Format: Address Street Number - e.g. "15" or "12B".
Registered Agent Address Street Name Optional Only valid for Company contacts. Detailed Format: Address Street Name - e.g. "Pitt" or "George".
Registered Agent Address Street Type Optional Only valid for Company contacts. Detailed Format: Address Street Type - e.g. "Road" or "Avenue".
Registered Agent Address Suburb Optional Only valid for Company contacts. Registered Agent Address Suburb
Registered Agent Address State Optional Registered Agent Address State
Registered Agent Address Post Code Optional Only valid for Company contacts. Registered Agent Address Post Code
Registered Agent Address Country Optional Only valid for Company contacts. Registered Agent Address Country
Full Forwarding Address Optional This field can be used if your input forwarding address data has multiple address parts (e.g. street/suburb/state/post code/country) combined on one line/in the same cell.
Forwarding Address Line 1 Optional Simple Format: Street Address Line 1.
This field should not be mapped in conjunction with the full forwarding address or detailed forwarding street address fields (care of, building, unit type, unit num, street num, street name, street type).
Forwarding Address Line 2 Optional Simple Format: Street Address Line 2.
Forwarding Address Care Of Optional Detailed Format: Address Care Of - e.g. "C/- ABC Law Firm".
This field should not be mapped in conjunction with the full forwarding address or simple forwarding street address fields (street address lines 1 and 2).
Forwarding Address Building/Level Optional Detailed Format: Address Building / Level - e.g. "Building 2" or "Level 23".
Forwarding Address Unit Type Optional Detailed Format: Address Unit Type - e.g. "Flat" or "Unit" or "Suite".
Forwarding Address Unit Number Optional Detailed Format: Address Unit Number - e.g. "12" or "13B".
Forwarding Address Street Number Optional Detailed Format: Address Street Number - e.g. "15" or "12B".
Forwarding Address Street Name Optional Detailed Format: Address Street Name - e.g. "Pitt" or "George".
Forwarding Address Street Type Optional Detailed Format: Address Street Type - e.g. "Road" or "Avenue".
Forwarding Address Suburb Optional Forwarding Address Suburb
Forwarding Address State Optional Forwarding Address State
Forwarding Address Post Code Optional Forwarding Address Post Code
Forwarding Address Country Optional Forwarding Address Country
Full Forwarding PO Box Address Optional This field can be used if your input forwarding PO Box address data has multiple address parts (e.g. street/suburb/state/post code) combined on one line/in the same cell.
Forwarding Address PO Box Optional Simple Format: PO Box - e.g. "PO Box 123".
This field should not be mapped in conjunction with the full forwarding PO box address or detailed forwarding PO box address fields (PO box care of, PO box type, PO box num).
Forwarding Address PO Box Care Of Optional Detailed Format: PO Box Care Of - e.g. "C/- ABC Law Firm".
This field should not be mapped in conjunction with the full forwarding PO box address or simple forwarding PO box address field ("PO Box").
Forwarding Address PO Box Type Optional Detailed Format: PO Box Type - e.g. "PO Box" or "RMS" or "Locked Bag".
Forwarding Address PO Box Number Optional Detailed Format: PO Box Number - e.g. "123" or "2447T".
Forwarding Address PO Box Suburb Optional Forwarding Address PO Box Suburb
Forwarding Address PO Box State Optional Forwarding Address PO Box State
Forwarding Address PO Box Post Code Optional Forwarding Address PO Box Post Code
Forwarding DX Address Number Optional Forwarding DX Address Number. Only valid for Company contacts.
Forwarding DX Address Exchange Optional Forwarding DX Address Exchange. Only valid for Company contacts.
Forwarding DX Address State Optional Forwarding DX Address State. Only valid for Company contacts.
Notes Optional Notes for the Contact. Field not available on the Bill and Boost plans.
Additional Notes Optional This column can be used to map additional (one or more) input columns to the `Notes` field. All data mapped to this column will be combined into a single Notes field in Smokeball (separated by a new line).
Webpage Optional Web Page of the Contact. Field not available on the Bill and Boost plans.
Risk Assessment Optional The assessment of risk that the contact is involved in dubious business practices. If not mapped, this defaults to "Incomplete".
Client Due Diligence Type Optional Describes the type of due diligence check being conducted.
PEP Status Optional “Politically exposed person” status, whether the person is politically exposed in a way that may influence their risk assessment or AML status.
PEP Status Date Optional The date associated with the outcome determining whether the contact is a politically exposed person.
Financial Sanctions Status Optional Whether the contact is currently under financial sanctions, possibly impacting their ability to pay.
Financial Sanctions Status Date Optional The date associated with determining whether the contact is under financial sanctions.
Source of Wealth Optional The source of the contact’s wealth.
Source of Wealth Date Optional The date associated with the determination of the contact’s source of wealth.
Source of Wealth Description Optional Qualify the source of the contact’s wealth.
Source of Funds Optional The source of the contact’s payment funds.
Source of Funds Date Optional The date associated with the determination of the contact’s source of payment funds.
Source of Funds Description Optional Qualify the source of the contact’s funds.
Nature & Purpose of Business Relationship Description Optional Qualify the nature and purpose of the business relationship with the contact.
POA PEP Status Optional “Politically exposed person” status, whether the contacts' POA is politically exposed in a way that may influence their risk assessment or AML status.
POA PEP Status Date Optional The date associated with the outcome determining whether the contacts' POA is a politically exposed person.
POA Financial Sanctions Status Optional Whether the contacts' POA is currently under financial sanctions, possibly impacting their ability to pay.
POA Financial Sanctions Status Date Optional The date associated with determining whether the contacts' POA is under financial sanctions.
Birth First Name Optional Birth first name of the contact (if not current name). Field not available on the Bill and Boost plans.
Birth Middle Name Optional Birth middle name of the contact (if not current name). Field not available on the Bill and Boost plans.
Birth Last Name Optional Birth last name of the contact (if not current name). Field not available on the Bill and Boost plans.
Previous Names Optional Any previous names for the contact. Field not available on the Bill and Boost plans.
Marital Status Optional The marital status of the contact. Field not available on the Bill and Boost plans.
Special Needs Optional Special needs of the contact, e.g. wheelchair access, hearing or vision impairment. Field not available on the Bill and Boost plans.
VOI Completed Optional Indicate if the verification of identity is complete (Yes/No). Will default to No if left empty. Field not available on the Bill and Boost plans.
VOI Date Optional The verification of identity date (DD/MM/YYYY)
VOI Source Optional The verification of identity source, e.g., Australia Post, InfoTrackID, Face to Face. Field not available on the Bill and Boost plans.
VOI Reference Optional The verification of identity reference. Field not available on the Bill and Boost plans.
Driver's Licence Number Optional Driver's Licence Number. Field not available on the Bill and Boost plans.
Driver's Licence State Optional Driver's Licence State. Field not available on the Bill and Boost plans.
Tax File Number Optional Tax File Number (TFN) - A unique number issued by the ATO to identify individuals and entities for tax purposes. Field not available on the Bill and Boost plans.
Medicare Number Optional Medicare Number - A number used to access the public healthcare system and claim medical services and benefits. Field not available on the Bill and Boost plans.
Centrelink Reference Number Optional Centrelink Reference Number - An identifier assigned by Services Australia to access government payments and support services. Field not available on the Bill and Boost plans.
Corrections Reference Number Optional Corrections Reference Number - An identifier used by state or territory corrective services to track individuals within the corrections system. Field not available on the Bill and Boost plans.
Country Of Citizenship Optional Country Of Citizenship. Field not available on the Bill and Boost plans.
Nationality Optional Nationality. Field not available on the Bill and Boost plans.
Language Of Interpreter Optional Language of interpreter (if applicable). Field not available on the Bill and Boost plans.
Passport Number Optional Passport Number. Field not available on the Bill and Boost plans.
Passport Issue Date Optional Passport Issue Date (DD/MM/YYYY). Field not available on the Bill and Boost plans.
Passport Country Of Issue Optional Passport Country Of Issue. Field not available on the Bill and Boost plans.
Passport Expiry Date Optional Passport Expiry Date (DD/MM/YYYY). Field not available on the Bill and Boost plans.
Bank Account Name Optional Bank details, account name for the contact. Field not available on the Bill and Boost plans.
Bank Name Optional Bank details, bank name for the contact. Field not available on the Bill and Boost plans.
Bank BSB Optional Bank details, BSB for the contact. Field not available on the Bill and Boost plans.
Bank Account Number Optional Bank details, account number for the contact. Field not available on the Bill and Boost plans.
Tags Optional Tags for the Contact. Accepts multiple (; separated).
Unique Company ID Optional This field is only relevant to Person Contacts and can be used instead of "Company Name" when there are multiple Companies in the import file with the same name, and you need to link one of them to a Person.
Matters
Matter ID Required
Unique identifier used for Matter. This ID will not be visible in Smokeball and is an internal identifier only.
Matter Number / Reference Optional
Matter Description Optional
Matter Status Required
Branch Name Optional The Branch Office that the Matter relates to. Branch locations can be configured in the firm settings of your Account. Configured branches will then be available for selection.
Date Opened  Required DD/MM/YYYY
Date Closed Required if matter status = "Closed" DD/MM/YYYY
Matter Type Required Matter Type as listed in your previous legal software.
Billing Type Optional Picklist of supported Smokeball Billing Types.
Person Responsible Name or Email Optional Email address, name, or initials for the staff member to use as the Person Responsible on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Primary Person Assisting Name or Email Optional Email address, name, or initials for the staff member to use as the Primary Person Assisting on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Other Person(s) Assisting Name or Email Optional Email address, name, or initials for the staff member(s) to use as the Other Person(s) Assisting on the Matter (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Primary Introducer Name or Email Optional Email address, name, or initials for the staff member to use as the Primary Introducer on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Other Introducer(s) Name or Email Optional Email address, name, or initials for the staff member(s) to use as the Other Introducer(s) on the Matter (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Client ID or Email
Required
Can take multiple (separate entries with "&")
Contact ID or Email of the Client for the Matter. Must exist in Smokeball, or the contact import file for the current import.
Other Side ID or Email
Optional
Contact ID or Email of the Other Side for the Matter. Must exist in Smokeball, or the contact import file for the current import.
Other Sides Solicitor ID or Email Optional  Contact ID or Email of the Other Sides Attorney for the Matter. Must exist in Smokeball, or the contact import file for the current import.
Debtor ID or Email Optional Contact ID or Email Address of the Contact to use as the default Debtor (accepts a maximum of three, & separated). A Contact with this ID or Email must exist in Smokeball, or the Contact import file for the current import. Populate if you wish to set the default debtor for future invoices to a contact other than the Client of the Matter.
Tags Optional
Tags for the Matter. Accepts multiple (; separated). Tag colours will be applied at random during import, but can be edited later in Smokeball.
Archived Optional
Indicate if the Matter is Archived (Yes/No). If set to 'Yes', archive and destroy dates are required. To be archived, the status of the Matter must be Closed or Cancelled.
Archive/Box Number Optional
The archive or box number
Archive Location Optional
The archive location
Archive Comment Optional
Comments relating to the archive
Archived Date Optional
The archive date (DD/MM/YYYY). Required if the Matter is marked as archived.
Destroy Date Optional
The destroy date (DD/MM/YYYY). Required if the Matter is marked as archived.
Deleted? Optional Defaults to "No" unless supplied otherwise.
Matter Tags
Matter ID or Number
Required The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import.
Tags Required
Note: Tag colours will be applied at random during import, but can be edited later in Smokeball.
Matter Roles
Matter ID or Number
Contact ID or Email
Required Contact ID or Email of the Contact to use for the role. Must exist in Smokeball, or the contact import file for the current import.
Role Name
Required
The name of the role (e.g. 'Child', 'Council' etc.). Depending on the Smokeball Matter Type chosen for each Matter, predefined supported roles will be available for selection, however, custom role names are also supported.
Matter ID or Number
Date Field Required
The name of the critical date field.
If the supplied field is not supported, a suggested list of supported critical dates will be provided based on the matter type for each matter.
Supported fields can be browsed in the following report: Supported Date Fields Report
Date Value
Required
The date for the corresponding critical date field (DD/MM/YYYY).
Matter ID or Number
Archived Required Indicate if the Matter is Archived (Yes/No). If set to 'Yes', archive and destroy dates are required. To be archived, the status of the Matter must be Closed or Cancelled.
Archive/Box Number Optional The archive or box number
Archive Location Optional The archive location
Archive Comment Optional Comments relating to the archive
Archived Date Optional The archive date (DD/MM/YYYY). Required if the Matter is marked as archived.
Destroy Date Optional The destroy date (DD/MM/YYYY). Required if the Matter is marked as archived.
Account Balances
Matter ID or Number Required The ID or Number of the Matter associated with the Opening Balance. A Matter with this ID or Number must exist in Smokeball or the Matter import file for the current import.
Account Name
Required
Supported: Credit Account and any Trust accounts configured in the firm.
The account to import the Matter opening balance into. For Trust accounts, in addition to the default account, you can configure multiple other accounts in the firm settings. Configured accounts will then be available for selection here.
Opening Balance ($) Required The opening balance amount ($) - e.g., "1500.50". Must be above zero
Opening Balance Date Required The opening balance date (DD/MM/YYYY). For Trust accounts, as best practice, we recommend using the closing date from your previous system.
Activity Codes
Code Required A code used for the Activity (between 2-5 characters). Must be unique.
Type Required The type of activity (Fixed Fee, Time Based, Disbursement).
Description Required A short description of the Activity.
Rate ($) Required The rate ($) of the Activity - e.g. "100.50" or "500.00" or "0.00"
Duration (Hours) Required if Type = Time Based If type = "Time Based", the duration of the Activity in hours - e.g. "1.0" or "1.5" or "2.0" (if not set, will default to 1.0 in Smokeball).
Quantity Required if Type = Disbursement If Type = "Disbursement", the quantity of the Activity - e.g. "1.00" or "1.50" or "2.00" (if not set, will default to 1.0 in Smokeball).
Cost Type Optional
If type = "Disbursement", indicate if the cost type is Hard or Soft (defaults to "Hard" in Smokeball if left empty).
Hard costs are costs paid directly to the supplier, e.g. search fees. Soft costs are costs that your firm can choose to pass to the client, e.g. costs of printer paper and ink.
Unbilled Time & Fees
Matter ID or Number Required The ID or Number of the Matter associated to the entry. Must exist in Smokeball, or the matter import file for the current import.
Staff Name or Email Required Email address, name, or initials of the staff member associated with the entry. The staff member must already exist in the account or be included in the Staff import file being imported.
Date Required The date of the entry (DD/MM/YYYY)
Type Required The type of entry (Fixed Fee or Time Based).
Activity Code Optional
Optional. Must match a Code from an Activity Type in Smokeball, or the Activity Type import file for the current import.
Assigning an activity code to an entry will not override/set other entry details (description, rate, duration etc).
Subject Required A short Subject description of the entry.
Description Optional Description for the entry
Rate ($) Required The rate ($) of the entry - e.g. "100.50" or "500.00" or "0.00" (defaults to 0.00 if left empty).
Duration (Hours) Required if Type = Time Based If type = "Time Based", the duration of the entry in hours (allows 5 decimal places for precision). Must be equal to or above 0.01.
GST Inclusive Required
Yes/No.
By default, the entry is exclusive of GST. Indicate here if the time/fee amount is considered GST inclusive.
GST for time/fees is calculated based on the default GST rate set in the settings of your Smokeball account.
GST Exempt Required
Yes/No.
Indicate if the entry is exempt from GST (defaults to "No" if left empty).
Billable Required
Yes/No.
Indicate if the entry is billable (defaults to "Yes" if left empty).
Write Off Required
Yes/No.
Indicate if the entry is written-off (defaults to "No" if left empty).
Unbilled Disbursements
Assigning an activity code to an entry will not override/set other entry details (description, rate, quantity etc).
Subject Required A short subject description of the entry.
Quantity Required The quantity of the entry - e.g. "0.50" or "1.50" or "2.00"
Yes/No.
By default, the entry is exclusive of GST. Indicate here if the Disbursement amount is considered GST inclusive.
Unless overridden, GST is calculated based on the default GST rate set in the settings of your Smokeball account.
GST Override ($) Optional
Optional. Specify a custom GST amount for the item.
If left blank, GST will be calculated automatically using the default GST rate set in your Smokeball account settings.
Entering 0.00 will mark the item as GST Exempt.
You can also enter a specific GST amount (other than 0.00) to override the calculated GST for the item.
Billable Required Yes/No. Indicate if the entry is billable (defaults to "Yes" if left empty).
Write Off Required Yes/No. Indicate if the entry is written-off (defaults to "No" if left empty).
Cost Type Optional
Indicate if the cost type is Hard or Soft (defaults to "Hard" in Smokeball if left empty).
Anticipated Required
Yes/No.
Indicate whether the item is a regular Disbursement or an anticipated Disbursement (defaults to "No" if empty).
Supplier ID or Email Optional
Required if the entry is anticipated or is supplier paid. Enter the ID or Email Address of the Contact to use as the supplier.
The Contact must already exist in Smokeball, or be included in the Contacts import file for the current import.
Supplier Reference Optional Can be provided if the entry is anticipated, but becomes required once the entry is also supplier paid.
Supplier Payment Due Optional Required if the entry is anticipated (DD/MM/YYYY).
Supplier Paid Required Indicate if the entry is supplier paid (Yes/No) — defaults to "No" if empty.
Supplier Date Paid Optional Optional for anticipated entries that are not supplier paid. Required if the entry is supplier paid (DD/MM/YYYY).
Supplier Payment Method Optional The payment method used (Bank Transfer or Direct Debit). Required if the entry is supplier paid.
Supplier Account Name Optional Required if the entry supplier paid.
Supplier Payment Reference Optional Required if the entry supplier paid.
Invoices Basic
Invoice Number Required Must a be unique number with no leading zeros.
Debtor ID or Email Required
The ID or Email of the Contact who is the debtor on the Invoice (accepts multiple, & separated). Three maximum.
Matter ID or Number Required The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import.
Issue Date Required
The Invoice Issue Date (DD/MM/YYYY).
Will also be used as the date for Fee/Disbursement line items.
Due Date Required The Invoice Due Date (DD/MM/YYYY).
Title Required Title text for the Invoice. 255-character max.
Subtitle Optional Subtitle text for the Invoice. This will appear under the main Title. 255-character max.
Notes Optional Footer notes for the invoice. This text will appear at the bottom of the invoice.
Total Inc. GST ($) Required
Overall Invoice Total.
Must be above 0.00. Amount should be Inc GST - e.g. "1500.50" or "800.00" or "123.00".
Fee Total Inc. GST ($) Required
Fee portion amount.
Should be Inc. GST - e.g. "1500.50" or "800.00" or "0.00" or "123.00".
Fee Total GST Exempt Required
Yes/No
Indicate if the fee portion amount is exempt from GST.
Defaults to "No" if left empty, in which case GST will be calculated based on the default GST rate set in the settings of your Smokeball account.
Disb Total Inc. GST ($) Required
Disbursement portion amount.
Disb GST Override ($) Required
Optional. Specify a custom GST amount for the Disbursement portion.
Entering 0.00 will mark the Disbursement portion as GST Exempt.
You can also enter a specific GST amount (other than 0.00) to override the calculated GST for the Disbursement portion.
Amount Due Inc. GST ($) Required
Amount should be Inc GST.
Where Amount Due is less than the Total amount, a payment will be created and applied to the invoice automatically on import for the difference.
Payment Date Required when the Amount Due is less than the Total Amount
Required when the Amount Due is less than the Total Amount.
A payment will be created and applied to the invoice automatically on import for the difference.
Required.
Each invoice must have an assigned owner — the staff member who created or finalised the invoice. Enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported.
This will also be the staff member used for assignment of the Fee and Disbursement line items on the invoice.
Invoices Detailed
Issue Date Required The Invoice Issue Date (DD/MM/YYYY).
Fee Discount ($) Optional Discounting is an invoice-wide action. You can apply a flat-dollar discount to the time and fees portion of the invoice.
Note: You cannot apply a discount to the disbursement portion of an invoice.
Surcharge ($) Optional You can apply a surcharge by a flat amount on the invoice.
Surcharge Description Optional
Provide a custom surcharge description that will appear on the invoice (max 32 characters).
Note: If left empty or not mapped, this will default to "Surcharge".
Required.
Invoice Number Required The Invoice number associated with the item. An invoice with this number must exist in the Invoice import file for the current import.
Staff Name or Email Required Email address, name, or initials of the staff member associated with the item. The staff member must already exist in the account or be included in the Staff import file being imported.
Date Required The date of the item (DD/MM/YYYY)
Type Required The type of the item (Fixed Fee, Time Based, Disbursement ).
Subject Required A short Subject description of the item.
Description Optional If type = "Time Based", the duration in hours (allows 5 decimal places for precision). Must be equal to or above 0.01.
Rate ($) Required The rate ($) for the item - e.g. "100.50" or "500.00" or "0.00".
Duration (Hours) Required if type = Time Based If type = "Time Based", the duration in hours (allows 5 decimal places for precision). Must be equal to or above 0.01.
Quantity Required if type = Disbursement If type = "Disbursement", the quantity - e.g. "1.00" or "1.50" or "2.25" (must be equal to or above 1.00)
By default, the item is exclusive of GST. Indicate here if the amount is considered GST inclusive.
For Disbursements, you can also enter a specific GST amount (other than 0.00) to override the calculated GST for the item.
Write Off Required Indicate if the item is written-off (defaults to "No" if left empty).
Cost Type Optional
Anticipated Required If type = "Disbursement"
Yes/No.
If type = "Disbursement": Indicate whether the item is a regular Disbursement or an anticipated Disbursement (defaults to "No" if empty).
If type = "Disbursement": Required if the entry is anticipated or is supplier paid. Enter the ID or Email Address of the Contact to use as the supplier.
Supplier Reference Optional If type = "Disbursement": Can be provided if the entry is anticipated, but becomes required once the entry is also supplier paid.
Supplier Payment Due Optional If type = "Disbursement": Required if the entry is anticipated (DD/MM/YYYY).
Supplier Paid Required If type = "Disbursement" If type = "Disbursement": Indicate if the entry is supplier paid (Yes/No)—defaults to "No" if empty.
Supplier Date Paid Optional If type = "Disbursement": Optional for anticipated entries that are not supplier paid. Required if the entry is supplier paid (DD/MM/YYYY).
Supplier Payment Method Optional If type = "Disbursement": The payment method used (Bank Transfer or Direct Debit). Required if the entry is supplier paid.
Supplier Account Name Optional If type = "Disbursement": Required if the entry supplier paid.
Supplier Payment Reference Optional If type = "Disbursement": Required if the entry supplier paid.
Memos
Memo ID Required Unique ID for the Memo. This ID will not be visible in Smokeball and is an internal identifier only.
Matter ID or Number Required Required for all Memos. The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import.
Date & Time Required
Memo date & time (24-hour). Not visible in Smokeball Web but retained for historical reference. If not populated, will default to the date of upload (DD/MM/YYYY HH:MM).
E.g. 05/08/2024 14:30
Subject Required
Subject of the Memo (If not populated, where possible, the first 50 characters of the memo text will be used).
Maximum 200 characters.
Text Required Full Memo text (If not populated, where possible, the subject of the memo will be used).
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Memo. The staff member must already exist in the account or be included in the Staff import file being imported.
Tasks
Task ID Required Unique identifier for the Task. This ID will not be visible in Smokeball and is an internal identifier only.
Matter ID or Number Optional The Matter ID or Number of the associated Matter (optional). If supplied, must exist in Smokeball, or the matter import file for the current import.
Name Required Name of the Task
Description Optional Task description (max 8,000 characters)
Status Required Task Status (Complete or Incomplete)
Created Date Required Date the Task was created (DD/MM/YYYY)
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Task. The staff member must already exist in the account or be included in the Staff import file being imported.
Assignee Staff Name or Email Optional Email address, name, or initials of the staff member to use as the Task assignee (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Due Date Optional Due date of the Task (DD/MM/YYYY)
Completed Date Required if status is "Complete" The completion date of the Task. Required if Status = Complete (DD/MM/YYYY)
Completed By Staff Name or Email Required if status is "Complete" Email address, name, or initials of the staff member who completed the Task. Required if Status = Complete. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported.
Duration Optional Duration of the Task (MM or HH:MM) - e.g. "01" or "15" or "1:30" or "01:06".
Calendar Events
Event ID Required Unique identifier for the Event. This ID will not be visible in Smokeball and is an internal identifier only.
Subject Required Name of the Event (255 character maximum).
Location Optional The Event location (255 character maximum).
Comments Optional Additional comments or description for the Event.
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Event. The staff member must already exist in the account or be included in the Staff import file being imported.
Attendee Staff Names or Emails Required or Group Calendar Name
Accepts multiple & separated.
Each Event must have at least one Staff Member or Group Calendar as the Assignee (or both).
For Staff, enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported.
Note: An attendee’s Calendar Event will only be visible in the application once imported if they are an active paying user or a former Staff member.
Group Calendar Name Required or Attendee Staff Emails
Accepts multiple, & separated.
Each Event must include at least one Group Calendar or Staff attendee (or both).
All Day Event Required Indicate if the Event is all day (Yes/No).
Start Date & Time Required The start date and time (24-hour) of the Event (DD/MM/YYY HH:MM).
Note: Smokeball does not allow bulk imports of events more than two years old.
End Date & Time Required The end date and time (24-hour) of the Event (DD/MM/YYY HH:MM).
Must be equal to or greater than Start Date Time.
Time Zone Optional
Optional: Time zone for the Event in IANA format (e.g. 'Australia/Sydney').
By default, the firm address set in the Smokeball settings will be used to determine the time zone for the event. This can be overridden if needed by providing a value in this column.
Billable Required
Indicate if the Event is Billable (Yes/No).
All day Events or Events longer than 12 hours cannot be marked as Billable.
Safe Custody Packets
Contact ID or Email Required The ID or Email of the Contact associated to the Packet (accepts multiple, & separated). Must exist in Smokeball, or the contact import file for the current import.
Packet Number Required The unique Packet reference number. Must be a unique number above zero.
External Ref. Optional Similar to Packet Number, but can cater for data from systems that do not conform to Smokeball validation requirements. If the Packet Number field cannot be used (due to validation concerns - e.g. duplicates, non-numeric values), this field can be used as an alternative and the Packet Number can be sequential numbering.
Storage Location Required The Packet storage location.
Notes Optional Notes for the Packet.
Created By Staff Name or Email Required Email address, name, or initials of the staff member who created the Packet. The staff member must already exist in the account or be included in the Staff import file being imported.
Created Date Required The date the Packet was created (DD/MM/YYYY).
Safe Custody Documents
Packet Number Required The Packet Number of the associated Packet. This Packet Number must exist in the Safe Custody Packet import file for the current import.
Document Type Required The type of Document - e.g. Birth Certificate
Document Number Required The unique document reference number per Packet. Must be a unique number above zero.
External Ref. Optional Similar to Document Number but can cater for data from systems that do not conform to Smokeball validation requirements. If the Document Number field cannot be used (due to validation concerns - e.g. duplicates, non-numeric values), this field can be used as an alternative and the Document Number can be sequential numbering.
Description Required Description for the Document.
Status Required The status of the Document (Held / Removed / Retrieved).
Reason Optional Reason/notes. For example, a reason why the Status is marked as Removed, Retrieved.
Received Date Required The date the Document was received (DD/MM/YYYY).
Last Movement Date Required if the status of the Document is Removed/Retrieved. The date of the last document movement (DD/MM/YYYY). Required if the status of the Document is Removed/Retrieved.
Created By Staff Name or Email Required Email address, name, or initials of the staff member who added/last updated the Document. The staff member must already exist in the account or be included in the Staff import file being imported.
6 out of 7 found this helpful
