The Costs Assessment (WA) matter type provides the necessary contact cards and layouts for Party–Party and Solicitor–Client Cost Assessments held in the Supreme Court.
You can select whether you act for the Applicant or Respondent.
The following Contact Cards and Layouts appear by default on a Cost Assessment (WA) matter:
- Applicant and its sub-layout Details where you can select whether the applicant will be paying or recovering costs and where the total costs value can be entered
- Respondent and its sub-layout Details where you can select whether the respondent will be paying or recovering costs and where the total costs value can be entered
- Case Details
Enter the case number, registry, division, list and court details
- Previous Solicitor
- Additional Contact
Precedent Library
The Cost Agreement (WA) matter provides access to the Litigation (WA) Precedent Profile with pre-set Precedent Library folder File Setup which include non-legally drafted precedents for everyday use, together with shortcuts to commonly used documents found under Court & Authority forms:
