Using the Archie Prompt Library
You can save, edit, and combine Archie prompts you have written for easy re-use. Each prompt you write for Archie can also be stored and retrieved from the Smokeball Precedent Library, and you will have access to prompts written by Smokeball in addition to your custom prompts.
Accessing the Prompt Library
  1. Open a matter and select the Archie tab.
  2. Select Prompt Library from the top-left panel.
  3. You can also access the Prompt Library by clicking on the Library icon in the chat box and selecting Prompt Library.
Selecting the three vertical dots next to a prompt will allow you to open, duplicate, or delete a prompt.
Create a prompt in the Prompt Library
Smokeball's Prompt builder is a powerful tool that allows you to create prompts as simple or complex as you like. To start populating the Prompt Library, follow this guide on creating a new prompt in the Prompt Library.
Save a prompt from your conversation history to the Prompt Library
If you have prompts that you have frequently use, save them to the Prompt Library for yourself and your firm for easy access.
  1. Open a matter file and select the Archie tab.
  2. Select a prompt you previously used in the left panel.
  3. Select the book icon and then select Create in the pop-up window.
The Prompt editor will open in a new window and you will be presented with multiple options for editing the prompt:
    1. Click the pencil icon in the upper left to edit the prompt name, associated matter type(s), and description.
    2. At the top of the screen, you can toggle between the editor and an isolated testing environment to test your prompt.
    3. Select who can see the prompt from the drop-down menu on the top-right corner of the screen.
    4. Use the Steps section to add and/or re-order prompt actions as needed. You can also use the toggle to make sure a document is selected to run the prompt.
    5. Enter your prompt for the relevant step in the Prompt field.
For more information on how this screen works, refer to our article on creating a prompt to use in the Archie Prompt Library.
All changes you make in the Prompt editor are automatically saved. When you're done, close the window and reopen the Archie tab in the matter.
The prompt will then be available in the library. Click on the pencil icon to edit the prompt or the play icon to run it.
Use an Archie prompt created by Smokeball
Several pre-configured Archie prompts exist to help you get started. These prompts are indicated by Smokeball in the Created By column and will appear in the Prompt Library along with your personal and firm prompts.
Save a prompt to the Precedent Library
You can also save an Archie prompt to the Smokeball Precedent Library:
  1. Select the Precedent button from within your matter.
  2. Select Add a precedent and select the Archie Prompt tab.
  3. Find the prompt from the two drop-down menus at the bottom of this window.
    • The first drop-down menu allows you to choose from either Your Prompts, your Firm's Prompts, or Prompts created by the Smokeball Team.
    • The second drop-down menu displays all prompts under the category selected in the first drop-down menu. For example, if you chose Your Prompts, it will display all prompts only visible to you.
  4. To use the prompt, double-click on it from the Precedent Library. Archie will open in a new window and run the prompt.
5 out of 5 found this helpful
