Create a prompt to use in the Archie Prompt Library
The Archie Prompt Library is a collection of prompts that you and your team can use as a shared repository of prompt resources for your firm.
This article will guide you through creating a prompt for use in the Archie Prompt Library. Learn more about the Archie Prompt Library in general.
Archie Prompts can be simple or complex, allowing multiple prompts to run in sequence with a single click.
Why should I use the Archie Prompt Library?
There are many benefits to storing and using prompts in the Archie Prompt Library:
  • Easily share the prompts you create, so other staff members can use them in their matters
  • Set your own guardrails or rules for prompts such as always forcing the output to show the same headings and formatting (using the Text actions and Sample Output features)
  • Chain prompts together, so you can run multiple prompts at a time in succession
  • Launch prompts directly from the Smokeball Precedent Library without navigating to the Archie tab
Accessing the Prompt Library
  1. Open a matter and select the Archie tab.
  2. Select Prompt Library from the left panel.
  3. You can also access the Prompt Library by clicking on the Library icon in the chat box and selecting Prompt Library.
Selecting the three vertical dots next to a prompt will allow you to open, duplicate, or delete a prompt.
Creating an Archie Prompt
  1. Select Add Prompt from the top-right corner of the Prompt Library.
  2. Enter the Name and Description of the prompt. These fields appear when you browse for the prompt from the Archie input bar.
  3. In the Key phrases for suggested prompts, enter a brief phrase or summary on what the prompt is about, e.g. Summarise a matter.
    • Key phrases are used for searching for a prompt in the Prompt Library.
  4. Click on the Matter types drop-down menu and tick all matter types this prompt will appear in.
  5. Select Create. The Prompt editor will open.
Using the Archie Prompt editor
The Archie Prompt editor includes sections for building prompts and a testing area to refine them as you go. Changes are saved automatically, so you can close the window and return later without losing progress.
Setting Prompt permissions
The first thing you should do when entering the editor is to indicate who can see this Archie Prompt. Make a selection from the top-right corner of the Prompt editor:
Understanding the Steps menu
The Steps menu on the left displays all prompts and static text blocks. If you are chaining multiple prompts together, they will appear in this list and run in the specified order.
(Optional) If you wish to have the prompt generate an answer based on a document, select Request document.
The Prompt Output button at the bottom of the Actions menu contains some advanced settings for further customisation of your Archie Prompt. You can choose to run all actions as a single prompt, customise the response outfit or set the format of the output in a set way.
Building the Prompt
The main section of the Prompt editor is where you enter the details of the prompt.
To get started, enter the Name that appears in the Actions section.
In the Type drop-down menu, select Prompt.
The second option, Text, allows you to add static text anywhere in the Archie Prompt. For example, if you want to add an AI disclaimer at the bottom of your output, you can enter the exact wording as a Text action.
Below is another example on using a Text action as a formatted heading between Prompt #1 (Client/Matter Details) and Prompt #3 (Overall Matter Summary):
No action is needed on the Relevant Information drop-down menu. This is automatically configured depending on if you have selected Request document or not from the Actions section earlier.
Now it's time to write the prompt - enter your prompt in the Prompt box.
(Optional) Sample Outputs
Clicking on Add a Sample Output will display an additional text box for this prompt. It is used as a way to set a reference or specific guidelines that will always be considered when you generate this prompt. You can add multiple Sample Outputs as needed; one might define required headings, while another could include a sample letter template.
Below is an example prompt incorporating a Sample Output:
"I am drafting a letter to my client. Use the below sample output and replace it with the personal information on this matter."
Adding, deleting and re-ordering Steps
Select Add/Edit at the top of the Steps section to open the Edit Steps window.
To add a new step, i.e. run another prompt before or after the prompt you just created, select Add step.
To rename a step, click on the step name.
To delete a step from the list, select the bin icon next to the name of the step.
To rearrange the order of steps, use the arrow buttons to move them up or down.
Testing your prompt
You can run the prompt at any time by selecting Test Prompt at the top of the editor. This brings you to an isolated Archie testing environment where you can test the prompt on any matter.
Once you select a matter, the prompt will run automatically. Note that more complex prompts may take longer to run.
3 out of 4 found this helpful
