Configure Archie Settings
Learn how to access Archie Settings to further customize your Archie experience in matters and leads.
  1. Open a matter or lead in the Smokeball Desktop App or Web App.
  2. Select the Archie tab.
  3. Select Settings on the bottom-left corner of the screen.
List of Archie Settings
Show AI model options
Select the drop-down menu to choose another model to experiment with.
All models made available have passed our privacy and security review. They do not share, use, store or train on our users data.
  • OpenAI GPT-5.2 (default): Balanced, fast, and reliable for everyday work such as drafting, summaries, quick questions, and routine matter analysis. The recommended starting point for most users.
  • OpenAI GPT-5.2 (Thinking): The same model with extended reasoning. Use it when a task needs more careful, step-by-step analysis, multi-document review, spotting ambiguity, or working through complex instructions.
  • OpenAI GPT-5.3 and 5.4: Newer GPT releases with incremental gains in reasoning quality and instruction-following over 5.2. A solid step up when you want more capability without moving to the latest release.
  • OpenAI GPT-5.5: The latest GPT release, building on 5.4 with stronger reasoning, better instruction-following, and improved consistency on longer tasks. The most advanced GPT option in the line-up, well suited to demanding drafting and analysis.
  • OpenAI GPT-5.5 (Thinking): GPT-5.5 with extended reasoning. Use it for the most complex work - detailed multi-document review, working through intricate or conflicting instructions, and tasks where careful, step-by-step analysis matters most.
  • Claude Opus 4.6: Anthropic's strong all-rounder, known for nuanced, natural legal writing and careful long-document handling. A great choice for correspondence, memos, and drafting where tone and precision matter.
  • Claude Opus 4.6 (Thinking): Opus 4.6 with extended reasoning; well suited to complex matters, cross-document analysis, and detecting conflicting or ambiguous terms across a file.
  • Claude Opus 4.7: The newer Opus release, building on 4.6 with improved reasoning and reliability. Choose this for the most capable Claude experience for demanding analytical and drafting work.
  • Claude Opus 4.8: The latest Opus release, building on 4.7 with further gains in reasoning depth and reliability. The most advanced Claude option in the line-up, suited to the hardest analytical and drafting work.
  • Claude Sonnet 5: Anthropic's fast, balanced option, tuned for quick turnaround on everyday drafting and analysis without a big step down in quality. A strong default when responsiveness matters as much as depth.
Ask follow-up questions for vague prompts
Enable this setting for Archie to start asking clarifying questions on prompts it considers vague. For example, if you ask "Draft an email to my client", it may respond with "Certainly, what exactly would you like to discuss with your client so I can draft the email?”.
Confirm file selection when asking about specific files in a prompt
Enable this setting if you would like Archie to confirm the file or document you are referring to in your prompt. This will appear if you ask Archie a question about a document without specifying the document first.
Use Advanced thinking for complex prompts
Enable this setting if you would like to see Archie's thought process listed out while it is generating a complex response.
Archie will determine if a prompt/question is complex in nature, and whether it should look for more relevant information than normal, and whether it should go into a deeper analysis for a better response.
Note that this will add to Archie's response time, but the end result should be more accurate.
Disable Advanced Text Extraction on PDFs
When Archie is asked a question about a PDF, a check is done in the back end to ensure the text has been extracted successfully for that PDF before running the prompt. If not, it is run through an advanced extraction tool to ensure Archie has the best chance at a great response.
The advanced text extraction process may take a considerable amount of time so the option is available to disable this from running.
7 out of 10 found this helpful
