Convert a lead to a matter
Plan_BoostGrowProsper.svg Addon_Intake.svg
Once your firm retains a client you can convert the Lead to a Matter.
Convert a lead on the Smokeball Desktop App
To convert a lead to a matter in the Smokeball Desktop App:
  1. Open the lead file.
  2. Select the Convert to Matter button above Lead Details.
  3. Choose the matter type to convert this lead to. The Current Lead Type and Matter Type converting to fields display near the convert button for reference.
    • Smokeball auto-selects the matter type if the lead has the same name in the same category.
  4. Select Convert. You will be prompted to confirm the conversion as you will not be able to convert the matter back into a lead.
  5. If the Lead Type and Matter Type are 100% compatible, you can continue to complete the matter details.
  6. If you are converting a lead into an incompatible matter type, there may be fields in the lead that cannot be brought across. Smokeball removes the incompatible data from the matter. Confirm you are ready to proceed by ticking I have read the above message and selecting Yes.
    • Make a note of the data before conversion for placing in the converted matter. Memos or contact cards can hold data in the new matter.
Once converted, the heading colour changes from dark green to dark blue and the icon changes from (L) to (M).
If you've enabled automatic matter numbering, Smokeball assigns a Matter Number/Internal Reference.
Convert a lead on the Smokeball Web App
To convert a lead to a matter on the Smokeball Web App:
  2. Select Convert Lead to Matter on the top-right corner of the screen.
  3. Choose the State, Practice Area and Matter Type you wish to convert the lead to.
  4. Based on your selection, the Client Role drop-down menu will be updated with the appropriate roles (e.g. selecting Family > Divorce as the matter type will allow you to select Applicant or Respondent for the Client Role).
  5. Select Convert to Matter.
25 out of 29 found this helpful
