Download and set up the Client Portal mobile app
To simplify the sign-in process and access to your messages from a law firm, we highly recommend downloading the Communicate Mobile App.
Select the links below to download the app for your device:
Setting up the mobile app for the first time
  1. Open the app on your device, then select Sign in.
  2. Enter your email address in the login page, then select Sign in to Communicate.
  3. Open the email sent to your email address, then select View Conversations.
  4. Navigate back to the mobile app.
The mobile app will keep you logged in until you sign out of the app.
App Security
You can also set up extra security on the mobile app, including turning on the Lock with Passcode feature or enabling Face ID.
To access security settings, select the three dots in the top-right corner of the mobile app, then select Security.
10 out of 14 found this helpful
