Notary Public
 To create a new Notary Public matter, follow the steps below.
  2. Select the State in which you are a Notary Public.
  3. Select Matter Type: Notary Public.
  4. Select 'Next':
  5. Enter your Client details, and any relevant Other Party, Government Department, or Additional Contact:
Change existing General matter to Notary Public
Existing General matters can be easily changed to Notary Public as follows:
  1. Open your existing General matter (used for Notary Public)
  2. Open Matter Type
  3. Select change...
  4. Select new Matter Type as Notary Public > Notary Public
  5. Select OK:
  6. Enter Reason For Change
  7. Select OK:
Your matter will now appear as 'Notary Public', with the party roles and layouts that are available in the Notary Public matter:
